torsion bars #826660 07/24/07 11:58 AM
twholland Offline OP
Want to adjust my t-bars, but first i would like to know how long (far out) the adjusting bolts should be sticking out stock. Reason being is that i bought the truck used and i'm not sure if they adjusted the t-bars already. The bolts are sticking out about 1.25-1.5". Is it OK to tighten down further???
'97 T100 XCab 4X4 SR5, 3" BL, 33x12.5 BFG A/T, Warn hubs, Ranchos
Re: torsion bars [Re: twholland] #826661 07/24/07 04:31 PM
Jake97T Offline
how much clearance do you have between the upper control arm and the droop stop?
Re: torsion bars [Re: Jake97T] #826662 07/25/07 05:53 PM
I don't know exactly where to measure? <img src="/forums/images/graemlins/confused.gif" alt="" /> any pics to discribe would be great. thanks.
Re: torsion bars [Re: twholland] #826663 07/25/07 07:11 PM
Jake97T Offline
on the frame there is a bracket with rubber bump stop on it that prevents the front suspension from drooping too far...its below the upper control arm towards the back side...
Re: torsion bars [Re: Jake97T] #826664 07/26/07 08:16 AM
oh, those bump stops.... it looks i have about 0.25-0.5" space on the upper stop and about 1-1.25" on the lower.
Re: torsion bars [Re: twholland] #826665 07/26/07 05:46 PM
Jake97T Offline
i wouldnt go much higher, youll limit your up travel, which is pretty important to keep those front tires on the ground both on and offroad, you could put some low profile bumpstops on there if you do want to go higher, higher you go the harsher the ride...
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.013s) Memory: 0.6100 MB (Peak: 0.6788 MB) Data Comp: Off Server Time: 2026-10-24 03:24:54 UTC
