timing belt - do h20 pump too?? #826701 07/24/07 07:06 PM
Darryl Offline OP
So it is time or a little past time to get the timing belt changed on my 99. When shopping around for pricing, I have gotten 2 quotes from the dealer and others. One for just changing the belt and another for doing the water pump and the belt. I am assuming I should just do the pump at the same time but wanted to get thoughts since it is around $200 more. What is the average life span of the factory installed water pump?
Also, if anyone has had their timing belts done recently, what have you been paying so I can compare.
Thanks!
d in utah
Re: timing belt - do h20 pump too?? [Re: Darryl] #826702 07/25/07 12:27 AM
W
Whizkidder Offline
I'd do the whole job yourself and save big bucks on labor charges -- it isn't that hard, and there is a great tech article on this website.
IMHO, water pumps aren't expensive enough to not replace them when you do the belt -- Toyota stuff does last longer than other brands, but who wants the hassle of having to basically re-do the belt because the old pump starts to leak?
Re: timing belt - do h20 pump too?? [Re: Darryl] #826703 07/25/07 04:35 PM
fourwd1 Offline
Typically when doing a job like a timing chain/belt, replacing parts removed as part of the job (ie, H2O pump, belts,hoses) is a good idea. They will fail, probably sooner than later. Unless those parts have already been replaced recently.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5948 MB (Peak: 0.6483 MB) Data Comp: Off Server Time: 2026-10-22 04:05:31 UTC
