scary vibration #826992 07/26/07 12:10 AM
IceBlueT Offline OP
well, here goes...
i pulled a tractor yesterday with my truck for my dad. i towed it at no more than 15 mph, in first to second gear. it was pretty heavy (5000 lbs. +), and took alot of effort. afterwards, i noticed a vibration. the vibration shows up in all gears, around 1500 and 3000 rpms, then goes away. im really confused. the vibration isnt present unless the truck is moving and in gear, so i think that eliminates motor problems. any ideas?
formerly 277000_yota
Old enough to know better, but still to damn arrogant to care...
]www.cardomain.com/ride/2614269
'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P)
'98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
Re: scary vibration [Re: IceBlueT] #826993 07/26/07 12:04 PM
foxtrapper Offline
Check your driveshaft. If you've got a two-piece unit, pay particular attention to the rubber bushed center bearing.
'97 T-100 SR5
Re: scary vibration [Re: foxtrapper] #826994 07/27/07 02:04 PM
missouriman Offline
check u joints as well as your lug nuts.
is there any sound?
Re: scary vibration [Re: IceBlueT] #826995 07/29/07 07:05 PM
VanillaTHUNDA Offline
Have your wheels/tires balanced, too.
Re: scary vibration [Re: VanillaTHUNDA] #826996 07/29/07 08:45 PM
mudrunner88 Offline
What speeds are you traveling when this happens? If you feel the vibe and push in the cluth does it go away?
If it's 4WD than the rear driveshaft and take it for a spin to help isolate what area it's coming from.
I would put my cash on the U-Joints were worn and you just did them in towing the tractor.
Re: scary vibration [Re: mudrunner88] #826997 08/01/07 07:30 AM
IceBlueT Offline OP
haha...i feel REALLY, REALLY stupid...i found the problem...i had to fix my makeshift exhaust hanger, and i accidentally tightened it too much, making the tail pipe vibrate against the underside of the bed...i loosened the hanger, and the vibration went away...
so, once again, i feel REALLY REALLY stupid... <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: scary vibration [Re: IceBlueT] #826998 08/01/07 11:59 AM
missouriman Offline
ok,, now I know the vibration <img src="/forums/images/graemlins/smile.gif" alt="" />
I hit a rock on sunday and mashed the tail pipe up against the bottom of the bed..
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6167 MB (Peak: 0.6909 MB) Data Comp: Off Server Time: 2026-06-22 06:14:27 UTC
