Page 2 of 3 1 2 3
Re: 22re high idle when warm [Re: MAC] #827088 08/12/07 05:52 AM
babyhuey Offline
vacuum leak!!
Re: 22re high idle when warm [Re: MAC] #827089 08/12/07 06:39 AM
MAC Offline
May be a dumb question, but did you try to close the throttle plate by hand? Or maybe a simple (not simple to find necessarily) vacuum leak i.e. hose etc?
woops I see that you checked the plate definitely closing above.
Re: 22re high idle when warm [Re: Kaptain] #827090 08/13/07 08:21 PM
applesauceman55 Offline
Check your dashpot.
1994 Pickup 4X4 22R-E 5 speed
Re: 22re high idle when warm [Re: applesauceman55] #827091 08/20/07 07:53 PM
Kaptain Offline OP
Check your dashpot.
As mentioned before it's been cleaned and lubed so it's definitely not sticking...
In addition I haven't put it back on since I cleaned the throttle body.
So anyway, I performed a test with the idle by-pass valve by putting a piece of tape over the port in the throttle body. Not to my suprise this affected my idle; I had to back out the Idle mixture screw (to where it used to be when all was well) and it idled just fine when it was warmed up.
I guess I'm going to fork out some dough for a replacement or find another throttle body assembly to test it with first. I'll keep this thread updated...
93' Toy xCab
bobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
Re: 22re high idle when warm [Re: Kaptain] #827092 08/22/07 04:23 PM
Kaptain Offline OP
Update...
I scored a 93 throttle body with a TPS for 60 bucks! (Car-parts.com) which I'll be getting next week.
I'm just going to swap the entire TB over and give that a shot, with a little luck this will take care of it.
Even if it doesn't it's not a total loss since I'll have an extra TPS laying around.
93' Toy xCab
Re: 22re high idle when warm [Re: Kaptain] #827093 08/26/07 08:32 PM
Kaptain Offline OP
Another Update...
I cleaned up the junk yard throttle body and got it installed today... It runs exactly the same as before, eliminating the Idle Air Control Valve and the TPS as the problem.
I'm running out of ideas at this point and I'm not sure what else to check... <img src="/forums/images/graemlins/scared.gif" alt="" />
93' Toy xCab
Re: 22re high idle when warm [Re: 4Crawler] #827094 08/31/07 02:20 AM
jimIIIIII Offline
Just had the same problem with my 93 xcab this last spring. I replaced the dashpot and the problem went away.
Re: 22re high idle when warm [Re: jimIIIIII] #827095 11/05/07 08:10 PM
Kaptain Offline OP
Here's an update on this annoying issue.
I took off and cleaned the EGR and verified that all the vacuum lines were routed correctly. My idle is still fubared - even worse with the colder temperatures.
Here's a re-cap of what's been done...
TPS adjusted and working correctly
Fresh coolant - burped properly
New Thermostat
Vacuum lines routed correctly
Coolant Temp sensor replaced
Throttle body thoroughly cleaned
Throttle body swapped with another one (to test the idle air control valve)
Dashpot cleaned and NOT sticking
Throttle cable lubed and NOT sticking
Timing set at 5 degrees
No check engine codes
Idle screw is IN the entire way
And like before; if I'm crawling or idling for a long period of time (15 minutes or so) my idle will gradually drop to where it's supposed to be - I even have to adjust my idle screw out a few turns.
Any other thoughts?
Triple check the vacuum lines?
Is there an Air Temp sensor on or near the AFM?
93' Toy xCab
Re: 22re high idle when warm [Re: Kaptain] #827096 11/05/07 08:17 PM
4Crawler Offline
Yep:
- http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml#AFMtesting
Re: 22re high idle when warm *Fixed* [Re: 4Crawler] #827097 12/18/07 01:40 AM
Kaptain Offline OP
I found the problem tonight.. Wow, am I ever relieved!
Here is it - clogged coolant passage from using 'Stop-Leak' in the past. This prevented fresh / warm coolant from making it to the temp sensor... The ECU was only sensing that the engine was cold which in turn increased amount the fuel = high RPM's and a very rich condition.
Thanks for all of the suggestions guys - hope this helps anybody in the future with a similar problem.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.006s) Memory: 0.6392 MB (Peak: 0.7646 MB) Data Comp: Off Server Time: 2026-10-21 20:44:37 UTC
