Page 3 of 3 1 2 3
Re: 22re high idle when warm *Fixed* [Re: Kaptain] #827098 12/18/07 03:20 PM
L
longhaul Offline
Good work, Kaptain. Congrats to you on (finally) getting this solved!
Would a 22R with a Weber 32/36 demonstrate the same symptoms if there was a clogged cooling passage? I can't see how it would but my truck is idling high and the dash temperature gauge is reading lower than normal...
Is there a way I can make sure coolant is cirulating through the engine? Is there any way the engine would at normal temp if coolant wasn't circulating?
ALSO- is it common for the truck (with the Weber) to run different when it's cold outside than when it's warm outside?
Thanks all!
Re: 22re high idle when warm *Fixed* [Re: longhaul] #827099 12/18/07 04:12 PM
4Crawler Offline
Thanks all!
Could be a thermostat that is stuck open or even missing. Might be worth pulling it out for a check.
Re: 22re high idle when warm *Fixed* [Re: 4Crawler] #827100 12/18/07 05:23 PM
Kaptain Offline OP
Thanks all!
x2 - if you haven't changed the t-stat lately I would check that first.
93' Toy xCab
bobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.009s) Memory: 0.6020 MB (Peak: 0.6720 MB) Data Comp: Off Server Time: 2026-07-16 03:41:16 UTC
