ELocker #827149 07/26/07 09:33 PM
TyYota Offline OP
I'm giving the Elocker serious consideration. I've read all the write ups I can find. I have a few more questions.
To fit my '92 pick up can I use a diff out of a Tacoma or do I need one from a 4runner?
How will my '92 ABS wiring connect to the Elocker diff?
Will typical 4cyl or V6 Ring and pinion fit the Elocker? What install kit will I need?
'92 Toyota, 4x4, 22RE, winch, locker, 4.88's, 33's, 2" Body Lift.
Re: ELocker [Re: TyYota] #827150 07/26/07 09:43 PM
Adam F Offline
4Runner and Tacoma E-locker are the same.
The ABS will not work with the elocker. You'll have to pull the fuse for the ABS, and you'll no longer have ABS.
Standard V6 r/p will fit the elocker diff.
97 4R, stock, daily driver
Re: ELocker [Re: Adam F] #827151 07/26/07 11:12 PM
TyYota Offline OP
so even though the Elocker diff comes with ABS, I won't be able to reconnect abs in my truck? Some parts supplyers are trying to tell me I need a special Elocker install kit to put in the ring and pinion. Is this true
Re: ELocker [Re: TyYota] #827152 07/27/07 04:36 AM
Adam F Offline
On 2nd gen trucks, the single ABS sensor is built into the differential. The wire plugs right into the diff.
Newer 4Runners and Tacomas have 2 ABS sensors that are located on the end of the axle shafts, not in the differential. So the elocker does not have the hole in it that has the sensor.
I haven't set up my r/p yet on my elocker, but I don't believe you need anything special. You may have to swap pinion flanges (or re drill) since the bolt pattern may be different. I simply swapped the pinion flange from my old diff onto the elocker.
Re: ELocker [Re: Adam F] #827153 07/27/07 05:37 AM
CORunner93 Offline
I just did the e-lock mod to my '93 Runner....you definitely loose the ABS. Remove the wire tail coming from the body, there is a connector near the gas tank. Then use the wire holders for your e-locker wire harness. And, remove the fuse, as said earlier or your ABS light will remain on.
This mod rocks by the way.....so nice to be able to push a button and have full lock to get through mud or over a rock...and still have good snow drivablilty when it is not locked.
'93 4Runner - 3.4L 5VZ-FE, 2" body lift, on-board-air system, custom gauge cluster, rear e-locker, electric fan, custom built front and rear bumpers, sliders, 4,88 gears...all on 33x12.5's.
Re: ELocker [Re: Adam F] #827154 07/27/07 07:28 PM
jasonmt Offline
A V6 R&P will work but the Factory E-Locker gears have a larger 30 spline pinion compared to the smaller 27 spline on the V6 R&P so a 27 spline flange will be needed.
E-Lockers also require a larger carrier bearing on the side of the third that has the locking mechanism hence the supplier telling you a install kit that comes with bearings will be different than than a non E-Locker kit.
Re: ELocker [Re: jasonmt] #827155 07/27/07 07:48 PM
Adam F Offline
This must be only on certain elockers. I got mine from a '99 Tacoma TRD. The bolt pattern did not match my drive shaft, so I took the old pinion flange from my regular V6 third and put it on the elocker 3rd. So they both had to have been 27 spline.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6194 MB (Peak: 0.7096 MB) Data Comp: Off Server Time: 2026-07-14 21:06:45 UTC
