Flashing 4WD lights (help) #827162 07/26/07 11:46 PM
brubren3815 Offline OP
Top lights are flashing.. Have taken it in and out of 2h/4h many times to try to get it to reset. It engages in 4wd and the lights stop flashing. but when I let off the gas and try to disengage the lights keep flashing..I can feel the difference between the two so I can tell when 4WD is engaged. Any help here? I tried the search function but to no avail. My son drives this and I want to make sure all is well.. This is on my 93'....
Thanks.
B2
2002 XLS /LSD/Thule Rack /PIAA Extreme White headlamps /K+N system/Michelin LTX MS--KYB gas-adjust all around
95 LS-- Dual Bouncy Seats 234k and still rockin'
Re: Flashing 4WD lights (help) [Re: brubren3815] #827163 07/27/07 02:18 AM
Put it in neutral on an uphill grade. Let it roll backwards unbraked while you blip the throttle (for better vacuum) and weave the front wheels side to side. That always releases mine on the 95SR. Never have released while going forward...
Re: Flashing 4WD lights (help) [Re: brubren3815] #827164 07/27/07 03:42 AM
jmdt Offline
Sounds like your Xfer case is coming out of 4-wheel drive but your hubs aren't unlocking. This happens especially if the 4x4 isn't used very often. Mine seem to unlock better when I'm moving faster - how fast were you going when you put the lever to 2H?
When mine won't unlock going forwards I just put it in reverse and back up for about 10 ft. This has always worked for me, but the way fasteddy describes might work even better, so I'd try both ways.
If that doesn't do it then you probably have an electrical or vacuum issue <img src="/forums/images/graemlins/scared.gif" alt="" />, so hope that backing up does the trick.
Re: Flashing 4WD lights (help) [Re: brubren3815] #827165 07/28/07 05:50 AM
MontyGrant Offline
Seconded on the suggestion to drive in reverse for a distance of 5-50 feet or until the lights stop flashing.
This used to happen to me occasionally and everytime I put in reverse and backed up the flashing would go away.
-Grant
'98 Montero with 135k miles
Re: Flashing 4WD lights (help) [Re: MontyGrant] #827166 07/28/07 04:24 PM
blizi Offline
Hi, I have problem with 4wd light too. Right rear wheel light does not swich on when I start the engine. How can I change it if it does not work? <img src="/forums/images/graemlins/frown.gif" alt="" />
'96 SWB 2.8td AUTO
Re: Flashing 4WD lights (help) [Re: blizi] #827167 07/28/07 04:35 PM
hazy_daze Offline
If it's just a bulb, then it's behind the IP. Parts stores and Radio Shack should have them. Dunno if they have them in Georgia, though.
Re: Flashing 4WD lights (help) [Re: blizi] #827168 07/28/07 06:06 PM
G
generation_one Offline
Hey Blitz,
I think your 1996 model is probably more sophisticated than the 1993 model asked about here.
I dont know much about the newer stuff....maybe a sensor loose.
If you are in a hurry to find the answer, then you can start a new thread.
-good luck
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: Flashing 4WD lights (help) [Re: brubren3815] #827169 07/30/07 07:25 PM
Scottie2113 Offline
your front axle is not 'disconnecting' from your wheels. there is a free-wheeling clutch bolted onto the passenger side of the front diff. there are 2 wires going to a sensor within this clutch. you need to trouble shoot the 2 solenoid valves along with the vacuum system that operate this free wheeling clutch. more times than not, the solenoid valves stick open or closed or go bad altogether over time. the solenoid valves are mounted on the inside of the engine bay on the passenger side front fender just under the air intake from air box to throttle body. one is marked with a yellow dot and the other with a blue dot.
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6272 MB (Peak: 0.7260 MB) Data Comp: Off Server Time: 2026-06-17 11:42:25 UTC
