HEI distributor
#827179
07/27/07 02:46 AM
Will a HEI distributor from a chevy 3.8L V6 work in a 4.3L V6? I found one in a '82 chevy monte carlo but not sure if it would work.I am building a '97 vortec with a carb setup and need a non-computer distributor w/vacume advance. Also I do have a V8 HEI unit. Can it be reworked internally for a V6? Different pickup or module? I dont have any experience with these units. So any help would be great.
Re: HEI distributor
[Re: krome]
#827180
07/27/07 05:58 AM
The 3.8l distributor should work if it's long enough. The V8 one won't unless you replace the pole piece and the thingy that has 8 points on it instead of 6 (I can't remember what it's called right now <img src="/forums/images/graemlins/notooth.gif" alt="" />)
KG6VNX
Re: HEI distributor
[Re: krome]
#827181
10/08/07 12:21 AM
you need to make sure you get a "standard" HEI, not one that has the ESC. (Electronic Spark Control) You need one that has vacuum AND mechanical advance ONLY. I'm not sure if you'll find one of those in a V6 though, I think they all had ESC. What you need to do is get a standard V8 HEI dist and replace the magnetic pickup with one from a V6 model. I am not 100% sure, but I think the standard V8 module will still work just as long as you use a V6 pickup.
Re: HEI distributor
[Re: mechanic58]
#827182
10/08/07 03:26 AM
It is my understanding that the V-6 and V-8 spark modules are the same part number.
KG6VNX
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6022 MB (Peak: 0.6578 MB) Data Comp: Off Server Time: 2026-06-07 04:25:05 UTCValid HTML 5 and Valid CSS
