Lift kit/tire question #827251 07/27/07 03:09 PM
mikey3809 Offline OP
I just sold my lifted F150 in the spirit of family values, ie wife needed a van. Because of that I inherited her 2002 Rodeo, which I need to do something to. I'm thinking about the Calimini 3' deluxe lift and I would like to know hat wheel/tire combination can I run (meaning how BIG can I go). I'd like to go with 16" rims, but am flexible with the offset/spacers.
Re: Lift kit/tire question [Re: mikey3809] #827252 07/27/07 05:49 PM
Jonesy Offline
First off, welcome to the sight.
I offer the suggestion of staying away from Calmini. They make a good product(although a good portion of their kit is unnecessary) they are HORRIBLE to deal with, and the lead times on their kits are ridiculous. They may tell you they can ship it out withing a week, but in reality you will most likely end up waiting 2-4 months for the kit to show up.
WIth that said, I would highly suggest Matt at Indy4x. www.independent4x.com He is active on many of the boards and offers top notch customer service. His kit is more simple, however it is the parts that are needed or recommended, not a bunch of parts that aren't needed.
As for tire size, you will be able to fit a 265/75/16 or a 32x11.5x15. You will require a little trimmin at the base of the front wheel wells to reduce rubbing, although you will probably rub a litle at full lock and compression.
Again, welcome, and check out Matt at Indy4x..and if you have any more specific questions he is a good resource.
'97 Rodeo
3.2L V6
DOR 3" lift, 3"BL, DOR Boulder Bars, Tera-Low's, 33x10.5,Surco Safari Rack, Cobra CB, Rancho 9000's....andnNow with Half-Doors for the summer
Re: Lift kit/tire question [Re: mikey3809] #827253 07/27/07 06:16 PM
TrailMystic Offline
I also recommend Matt at Indy4X. Get his 3" suspension lift but don't get the manual hubs because they won't work on an '02 Rodeo. They changed the front axle in '02 so that there is a big nut instead at the end instead of a snap ring. There are no manual hubs that will work on an '02, so there will be increased stress on your cv joints because they will be turning all the time at an increased angle. But, a lot of guys run a lift on the '02 anyway. Diff drops reduce the angle. In my opinion, you don't need all the extra stuff in a Calmini kit. They are just trying to offer a "complete kit similar to other trucks, but some guys on this forum really like the extra stuff like the a-arms. The 265/75R16 works well with our Rodeos and there will just be easy overfender trimming to make it work.
Anubis (Bryan) has a lifted (3"+3") '02 Rodeo and you can pm him.
Pete
'01 Rodeo Sport, 5 Speed Softie, Indy 4X rocker bars, OME 912's, Rancho 9000X's, Superwinch hubs, custom tube bumper with Warn 9000i , Flowmaster 50, TeraLow t-case gears, ARB front & rear lockers, TrXus MT's, Sway bar disconnects
Re: Lift kit/tire question [Re: mikey3809] #827254 07/30/07 08:17 PM
AZRIDER001 Offline
I have to agree with the lead-time for Calmini kits. The first call was 8-10 week, second call was an additional 4-6 weeks. Amazing they called today with my '04 supn. kit. 9 weeks after placing the order. I also tried Independent, but to date they don't support the '04 model. I'll let you know how it goes after the install is complete. Calmini recommends 31x10.50 max tire size. With a little trim 33's can be stuffed on. In the sprit of family the wife got a new mini-van and I took the Rodeo.
Ernie
Re: Lift kit/tire question [Re: Jonesy] #827255 07/31/07 01:48 AM
If I use more of an off set rim, can I go bigger with the tire, or is turning not the clearance issue?
What is the offset on the rims are you using to put the 33"s on?
Re: Lift kit/tire question [Re: mikey3809] #827256 07/31/07 08:33 AM
rubo Offline
With just a 3" susp. lift you can forget about 33's no matter what offset you use (simply not enough room in the front).
You can do 3" susp. + 3" body which will allow using 33's or 34's with the right offset (ask bigpoppax2, he's running 34's).
For 32x11.50x15 or 265/75/16 you'r best bet is running the stock rims (for 16's) or 15" rims with similar offset.
If you go with neutral offset you'll rub even with 31's (i've got this set up) & you'll endup trimming anyway.
Than again if you don't mind doing A LOT of trimming you coulg fit 33's with just susp. lift (but it will not be pretty).
Just my $.02
"If i can't crawl over it, i'll fly over it"
rubo
'96 Amigo 4x4, 3.2L V6, 4L30E, D44 rear, SOA, 1" BL, undergoing surgery.
'00 Rodeo LS 4x4, 3.2L V6, OME 919 Springs, front cranked to match,1" BL, 265/70x16 Scorion A/T's.
Re: Lift kit/tire question [Re: AZRIDER001] #827257 07/31/07 02:04 PM
matthew Offline
....... I also tried Independent, but to date they don't support the '04 model.
<img src="/forums/images/graemlins/confused.gif" alt="" /> not sure what this is about. the 98-04 are the same kit.
we have actually done a 2004 rodeo (3" susp. 3" body - 285/75r16 Goodyear MTR w/ ARB bullbar) here in the shop.
anyway for the record.....we do 98-04 amigo, rodeo, rodeo sport. <img src="/forums/images/graemlins/wink.gif" alt="" />
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
Re: Lift kit/tire question [Re: matthew] #827258 07/31/07 03:39 PM
AZRIDER001 Offline
[quote]....... I also tried Independent, but to date they don't support the '04 model.
I called someone the first week of June and they told me the kit would only work up to 2003. That's why I went with Calmini.
So, If I add the 3" body lift 285/75r16's will fit nicely? <img src="/forums/images/graemlins/wink.gif" alt="" />
Ernie
Re: Lift kit/tire question [Re: AZRIDER001] #827259 08/01/07 05:19 PM
holger Offline
2002, 2003 and 2004 all have the same stuff in terms of suspension.
Some 2004s have different engine and different transmission, but this is not related to the suspension kit.
Oleg
Deceased Rodeo'02 4WD.
Re: Lift kit/tire question [Re: holger] #827260 08/01/07 08:02 PM
AZRIDER001 Offline
Thank you for the clearification. This is my first Rodeo <img src="/forums/images/graemlins/lol.gif" alt="" /> and it been hard finding aftermarket parts. I'm glad I finally found this site for help. It seems I wasted a ton of time before now.
Ernie
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6330 MB (Peak: 0.7433 MB) Data Comp: Off Server Time: 2026-06-07 09:10:10 UTC
