manual transmission thoughts
#827307
07/27/07 10:24 PM
I've got an 86 4runner with a freshly rebuilt 22RE. It currently has a G series transmission in it that works but is screaming loudly for a rebuild so I need to do something else. I would love to find a R151F for that little extra bit of strength, but so far they look to be scarce and pricey. In my looking around I happened to notice that the W59 is also a 23 spline output, and with a Marlin adapter can work with a gear drive transfercase. Does that sound like a reasonable substitute if I'm only ever going to have a 22RE or maybe years away a 3RZ?
Thanks, Ron
Re: manual transmission thoughts
[Re: netgodsrdn2]
#827308
07/28/07 04:04 AM
w56 is what i have in mine stock and it is matted to a gear drive transfercase....no adaptors or anything...yet
92' Pick-up, SAS, gears to make her crawl, 37's , bullet proof motor, and alot of time invested. 06 CRF450R one mean roost flinging machine
[Re: rednekbean]
#827309
07/28/07 05:07 AM
Yes the W56 will bolt right to a 21 spline gear drive t-case. I want to upgrade to a 23 spline for a little extra strength. The W59 is a 23 spline output but doesn't from the factory bolt to a 23 spline gear drive t-case. So you need the Marlin taco gear drive adapter as far as I've figured out so far. I'm still in the research phase here so if I'm mistaken someone please tell me...
Thanks, Ron
[Re: netgodsrdn2]
#827310
07/28/07 08:52 PM
The W56 swapped into my '84 has worked well.
84 4RUNNER,22R,HEDMAN,WEBER 32/36,Davis Unified Ignition,33" BFG
[Re: netgodsrdn2]
#827311
08/07/07 05:12 AM
I'm only bringing this back to correct myself and hopefully avoid confusing others...
The W59 is actually a 27 spline output, but marlincrawlers adapter will convert it to 23 spline to work with a gear drive t/c. I'm not sure how that impacts it's strength... I'm starting to think I really just need to save my pennies and get a R151F if I'm gonna do 23 spline...
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6035 MB (Peak: 0.6677 MB) Data Comp: Off Server Time: 2026-07-09 21:06:17 UTCValid HTML 5 and Valid CSS
