Trailing arms in the way -- options? #827343 07/28/07 05:13 PM
BlossomCA Offline OP
My trailing arms were hit several times on my last trip and are very obviously in the way (more so than the gas tank). As I understand it they are a result of the suspension lift by the truck's previous owner. But this can't be the standard. I've searched for "curved trailing arms", "angled trailing arms" and more with not much luck. Can you please give me some suggestions on where to look and what my options are?
Many thanks.
Joanna
Joanna
1992 Toyota 4Runner -- 3.0L V6, MT, 4.7 TC
Amateur Radio AE License
Re: Trailing arms in the way -- options? [Re: BlossomCA] #827344 07/28/07 05:30 PM
Jeff the marmot Offline
I'm not familiar with the early '90's 4Runners aftermarket lift kits, but that frame mount for your trailing arms definitely looks aftermarket. For me the stock frame mount of the trailing arms is annoying to get caught on rock ledges even without that crazy looking downward extension that's just asking for rocks to hang you up. The stock mount is in the bolt hole that's above the aftermarket mount's hole.
Does anyone know what brand of lift kit that is from?
You'll need to get different aftermarket swaybar endlinks since those ridiculously long ones are obviously aftermarket or homemade and seem to be the primary reason why they had to extend the link mount lower. You definitely don't need the swaybar horizontal in order for it to flex properly so I'm baffled why anyone would do that. That weird mount also made your pinion angle slightly worse. Is there a problem with rubbing or contact from the rear axle or rear tires that would necessitate moving the axle back a tad?
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
Re: Trailing arms in the way -- options? [Re: Jeff the marmot] #827345 07/28/07 06:45 PM
Adam F Offline
All pro sells some longer control arms to mount in the factory brackets
http://www.allprooffroad.com/index.php?option=content&task=view&id=122
Check out some of the 2nd gen suspension setups we have listed in our tech section
http://www.4x4wire.com/toyota/4Runner/tech/suspension/
97 4R, stock, daily driver
Re: Trailing arms in the way -- options? [Re: Adam F] #827346 07/29/07 08:32 AM
Thanks guys. I've been reading...
Joanna
Re: Trailing arms in the way -- options? [Re: Adam F] #827347 08/13/07 04:21 AM
I've received my new lower control arms from AllPro! They look strong and, yes, they are the perfect length for the new diagonal fit. <img src="/forums/images/graemlins/cheers.gif" alt="" />
We installed the first one this afternoon. As you can see the break line is tight and the sway bar endlink rubs on the bar.
Interestingly enough while we were down there I discovered that at some point I broke my rear sway bar in half. (This happen often? I thought the bushings looked fine!?) It must have been on the Rubicon, and since I never even noticed I'm considering removing it so it won't be in the way.
Joanna
Re: Trailing arms in the way -- options? [Re: BlossomCA] #827348 08/13/07 05:15 AM
OOP'S Offline
The next thing to break is the mounts for the arms and the panhard. They are not up to the stress that is put on them from rockcrawling. Remember if you remove the sway bar, it is not going to handle as well.
Some have fixed the problem with the links by cutting all that stuff out and installing leaf springs in the rear.
Here is a write up on installing leafs in the rear:
http://toyota.off-road.com/toyota/article/articleDetail.jsp?id=300933
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Trailing arms in the way -- options? [Re: BlossomCA] #827349 08/13/07 06:28 AM
av8soulfly Offline
Looks like your hang up problems are over. I've been running without sway bars for several years now, just be aware that you'll need more reaction time when something stupid happens in front of you on the highway.
DON'T MOVE!!!...Lemme get the camera!
Re: Trailing arms in the way -- options? [Re: BlossomCA] #827350 08/13/07 07:16 AM
kewlynx Offline
J-
Here's another option for ya; this would be something I'd do for a rock crawler. Oops, do you or any of the other guys have these?
http://www.4x4wire.com/toyota/reviews/disconnects/
There's another set of swayaways that are reviewed there too, your FYI. <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
Re: Trailing arms in the way -- options? [Re: kewlynx] #827351 08/13/07 05:32 PM
I've looked for RockStomper disconnects before but didn't see them on their website, figured they stopped selling them. Will research some more.
Joanna
Re: Trailing arms in the way -- options? [Re: BlossomCA] #827352 08/14/07 04:56 AM
Rockstomper disconnects are very noisy due to clicking heim joints and those pins. And that's before the heims wear and get noisier. Several years ago I endured the annoying noise of the Rockstomper disconnects and actually used them for quite a while until I blew them to pieces, but there are definitely much better solutions out there now.
Jeff
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.006s) Memory: 0.6447 MB (Peak: 0.7706 MB) Data Comp: Off Server Time: 2026-10-21 19:17:42 UTC
