Re: Trailing arms in the way -- options? [Re: BlossomCA] #827353 08/14/07 10:37 AM
4wheeler Offline
I've received my new lower control arms from AllPro! They look strong and, yes, they are the perfect length for the new diagonal fit. <img src="/forums/images/graemlins/cheers.gif" alt="" />
We installed the first one this afternoon. As you can see the break line is tight and the sway bar endlink rubs on the bar.
It looks to me like a 4" Pro comp rear lift to match the 4" IFS front lift.
You might want to check the upper control arms as the kit has extensions at the diff end to keep all the control arms parallel. If they are not all the same then your diff will rotate when it flexes offroad.
A std set of sway bar end links will fix the sway bar issue if you want to keep it.
HTH
Re: Trailing arms in the way -- options? [Re: 4wheeler] #827354 08/21/07 12:11 AM
BlossomCA Offline OP
So I'm thinking it was the rotation of the diff that ripped off the upper control arm on Dusy/Ershim two days ago. We discovered it and welded it on the trail, then it broke the weld less than a day later. Check this out.
Leaf springs are calling my name.
Joanna
1992 Toyota 4Runner -- 3.0L V6, MT, 4.7 TC
Amateur Radio AE License
Re: Trailing arms in the way -- options? [Re: BlossomCA] #827355 08/22/07 05:41 AM
ldivinag Offline
Interestingly enough while we were down there I discovered that at some point I broke my rear sway bar in half. (This happen often? I thought the bushings looked fine!?) It must have been on the Rubicon, and since I never even noticed I'm considering removing it so it won't be in the way.
i remember when mine snapped.
i heard a loud BANG.
a few weeks later, i was wheeling and someone pointed out something dangling from the rear end.
i looked and it was the sway bar.
btw, ever think of going a custom 3 link back there?
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: Trailing arms in the way -- options? [Re: Jeff the marmot] #827356 08/23/07 07:26 PM
dsalvetti Offline
...there are definitely much better solutions out there now.
Speaking of sway bar disconnects... what are the better solutions? I've been looking and have only found "Nuclear" which I believe are discontinued and then a build-your-own design from Lars.
I wish JKS made some for Toyotas!
~Dave
'98 4Runner SR5, 3.4L, 5-Speed, 4WD >>K&N, ISR, TRD Clutch, 265/75R16 Yokohoma Geolandar AT+II's, OME (880/N91SC, 906/N86C)>> SOLD to pay bills.
Re: Trailing arms in the way -- options? [Re: dsalvetti] #827357 08/24/07 01:42 PM
Jeff the marmot Offline
Either Nukes or Lars are much better than the old Rockstomper disconnects. I have 5 year old Nukes with heims that are very worn, so I'm considering building a pair of Lars' design. They are fairly similar, although Lars' disconnects are adjustable length and the heims look a little larger.
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6157 MB (Peak: 0.7135 MB) Data Comp: Off Server Time: 2026-11-02 04:00:42 UTC
