Problem with 4wd light #827358 07/28/07 06:16 PM
blizi Offline OP
I have problem with 4wd indicator light. When I start the engine, right rear wheel light does not turn on. How can I change it, if it does not work? Has it own light bulb? <img src="/forums/images/graemlins/frown.gif" alt="" />
'96 SWB 2.8td AUTO
Re: Problem with 4wd light [Re: blizi] #827359 07/30/07 07:19 PM
Scottie2113 Offline
yes, each wheel has it's own little light bulb. you can change them but have to take out gauge pod.
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5874 MB (Peak: 0.6354 MB) Data Comp: Off Server Time: 2026-06-22 06:13:44 UTC
