Exhuast Work AAAARRRRG #827585 07/30/07 02:45 PM
shoff Offline OP
THE TRUCK:
4runner with 22re. I have a complete rebuilt engine and am confused about the exhaust? I have piping that is 1.5" all the way back. I have a new magnaflow cat and a flowmaster 44 on its way.
THE ISSUE:
I have stock pipes that are 1.5" and smaller do to the fact they used a pipe bender to make them(see pic). I want to take these back and have good pipes bent up to 2" and 2.25".
THE QUESTIONS:
1. I have called around to several shops and nobody does muffler work. They just install stock. One shop said they could bend pipe and would charge for material and 70hr labor. How long should it take to match up the old pipes, I will do the install. Where do I go?
2. If the exit on the exhaust manifold is 1.5" wouldn't that be a problem to go into 2" pipes? (see pic)
3. The pipe that goes from the Manifold to the cat has a custom fit to the manifold. Do I have a shop make this and pay through the nose or is there a way I can get these parts to make it myself, parts being the backet that bolts to the manifold and the splitter pipe. (see pic)
Re: Exhuast Work AAAARRRRG [Re: shoff] #827586 07/30/07 05:20 PM
4Crawler Offline
Might consider a header, I installed an LC Engr. header and it has 2" tubing from the collector back to the cat:
http://www.4crawler.com/4x4/CheapTricks/EngineMods/index.shtml#Exhaust
I then made up my own cat-back exhaust, cutting off the stock pipe after the post-cat bend and using sections of straight and flexible s/s tubing:
http://www.4crawler.com/4x4/CheapTricks/TailPipe.shtml
Or just keep the stock downpipe and go bigger after the cat. I did that initially and it seemed to work fine.
Re: Exhuast Work AAAARRRRG [Re: shoff] #827587 07/30/07 06:34 PM
bkg Offline
THE ISSUE:
Confused... Stock is not 1.5" and smaller. How are you measuring? Internal or external diameter? Always measure the external diameter of the TUBE. Should be 2.0", IIRC.
THE QUESTIONS:
What do you want? Stock or after market? That rate is about right. Should run you about $150 to have the 2.25" made w/ you supplying the muffler. Now - some shops may not be happy with you supplying components as they make money off of the markup.
You're measuring wrong. There are two ports there - two cylinders each. Ignore that. You're only concerned about what is after the collector.
What's wrong with the one that you have? Use the stock one and run custom back from there.
Brian K. Gallus
Re: Exhuast Work AAAARRRRG [Re: bkg] #827588 07/30/07 07:29 PM
shoff Offline OP
Here is my the diameter, roughly 1.5" there are bends in it that decrease this more.
Re: Exhuast Work AAAARRRRG [Re: shoff] #827589 07/30/07 07:34 PM
4Crawler Offline
Yep, I recall my factory pipes were roughly 1-1/2" ID and 1-5/8" OD. For the first upgrade, I just used a 1-5/8" to 2" adapter behind the cat and ran 2" pipe back to the tail pipe.
Re: Exhuast Work AAAARRRRG [Re: shoff] #827590 07/30/07 07:40 PM
bkg Offline
Dang... I hate being wrong. <img src="/forums/images/graemlins/ignore.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" />
Brian K. Gallus
Re: Exhuast Work AAAARRRRG [Re: bkg] #827591 07/30/07 08:09 PM
shoff Offline OP
Well.......what do ya think I should do? For now I still have work on the engine and if I cant find out how to do this without spending more $$$$ then the 1.5 stock goes in.
Re: Exhuast Work AAAARRRRG [Re: shoff] #827592 07/30/07 08:55 PM
bkg Offline
only worry about the exhaust from the collector back... The stock 4 into 2 into 1 design is pretty decent (not great), so only mess with the area after the 2 into 1 collector. I'd go 2.25" all the way back. You can either have it custom done as you've noted or purchase something from Downey, Performance Products or any of the other companies out there that sell Toyota products.
Brian K. Gallus
Re: Exhuast Work AAAARRRRG [Re: bkg] #827593 07/30/07 09:39 PM
cktoy Offline
Use stock parts till you get past the 2 into 1.I wouldnt go with a header unless threre is something wrong with the ex manifold.not worth the money in my opinion.the truck is going to LOVE the bigger pipe.best mod Ive done
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: Exhuast Work AAAARRRRG [Re: bkg] #827594 07/30/07 09:43 PM
shoff Offline OP
So my exhaust should go ENGINE/STOCK EXHAUST MANIFOLD/STOCK 2 TO 1 COLLECTOR 1.5"/MAGNAFLOW CAT/CUSTOM PIPE 2.25"/FLOWMASTER 44 MUFFLER/CUSTOM PIPE 2.25"
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6479 MB (Peak: 0.7716 MB) Data Comp: Off Server Time: 2026-06-22 07:32:45 UTC
