Re: Exhuast Work AAAARRRRG [Re: shoff] #827595 07/31/07 02:55 AM
kewlynx Offline
Yep. Go any bigger than that and it'll suck. The engine's back pressure is pretty well dialed in with the exhaust.
**ubi apis- ibi salus**
Re: Exhuast Work AAAARRRRG [Re: shoff] #827596 07/31/07 03:16 AM
rednekbean Offline
Yeah that sounds about right. One thing you can do is 2" upto the muffler and a 2.25" tail pipe out of the muffler. That set up seems to work fairly well with a stock head, you increase throttle response keep bottom end and still gives you more top end.
The girl friend has stock manifold/ collector/ 2"pipe/ removed cat/ turbo muffler/ full tailpipe. All pipe on that is 2"from the collector back and her little motor has some pretty good go go, it will cruze at 85 down I-5 with quarter throttle in fifth turning 33's and 4.88 gears, also it is a 86 22re sr5 x-cab.
Either way increases flow which is what free's up pony's. However 2.25" is the biggest pipe that is effective, you do not want to go any bigger.
I bet that once you put the new exhaust o-ring donuts( they cost like a buck) on the collector it will fit nice and tight.
92' Pick-up, SAS, gears to make her crawl, 37's , bullet proof motor, and alot of time invested.
06 CRF450R one mean roost flinging machine
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.5952 MB (Peak: 0.6598 MB) Data Comp: Off Server Time: 2026-10-21 18:57:06 UTC
