Herculiner Question #827681 07/30/07 08:03 PM
samron333 Offline OP
I am going to be doing my bed soon with Herculiner and I am looking for someone that has done this after spraying the bed with primer paint. I have a lot of rust and want to sand it out and primer it to keep it from coming back. I know the paint needs to be roughed up and cleaned but I am looking for someone who has experience using it primer paint.
84 Longbed, 31 Mud Terrain SXT, rest is stock
CBR 1000, for when i need to hit sixty in less than thirty seconds
Re: Herculiner Question [Re: samron333] #827682 07/30/07 08:13 PM
mountain_warrior Offline
i dont have any experiencebut if youy sand it out then spray the heculiner wont that cover it and stop the rust from getting worse?
cory <img src="/forums/images/graemlins/cheers.gif" alt="" />
1988 swb montero/pajero
1995 sr montero
Re: Herculiner Question [Re: samron333] #827683 07/30/07 09:12 PM
I did some searching before posting and from what I read the Herculiner is not a rust inhibitor nor does it stick to bare metal that well.
Re: Herculiner Question [Re: samron333] #827684 07/30/07 09:30 PM
4Crawler Offline
When I did the Duplicolor liner in my VW pickup, I primed the bare metal areas then sanded and applied the liner. It's held up fine for about 7-8 years now.
Re: Herculiner Question [Re: samron333] #827685 07/30/07 09:32 PM
cktoy Offline
now that you mention it the only place mine has come loose is where I had bare metal showing and put herculiner over it.I used the cheaper "dupli-color" brand and I was well pleased.Ive thought of doing the fender wells too.
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: Herculiner Question [Re: cktoy] #827686 07/31/07 03:20 AM
Cholltero Offline
Best to sand blast it out if you can . At the very least , wire wheel as much of it out as you can and treat it with a mild phoshoric acid solution. If your not comfortable mixing up your own go to a auto body supply and buy premade metal prep. Let it soak good , wash it off, then prime.
85' 4x4 e-cab flatbed 22r carb ((SOLD))
86' 4runner, 22re , "60 buck truck"
95' 4runner, 22re,5sd, last of the good ones
02' Tacoma prerunner, 2.7L, 5spd., 4x4
Re: Herculiner Question [Re: samron333] #827687 07/31/07 05:05 PM
I was planning on using a wire wheel, did not know about the solution. I have never used that solution, how harsh is it? I only ask since you stated I might be uncomftorable.
I did go to Herculiners website and it does say that it can be used on primer. I forgot the rule; if all else fails, read the instructions. Thanks for the advice.
Re: Herculiner Question [Re: samron333] #827688 07/31/07 05:13 PM
4Crawler Offline
You can use something like CLR or LimeAway bathroom cleaner, both are phosphoric acid based. The acid will dissolve the rust a also roughen up the steel a bit. Just brush it on and keep it wet (brush on more acid) for about 30 minutes then rinse off and let dry. It'll leave a light surface "rust" coating of iron phosphate. You can get the real metal etching compound and it'll also have a zinc component to it in addition to the acid.
Re: Herculiner Question [Re: 4Crawler] #827689 08/05/07 03:29 AM
toyotateen88 Offline
i pulled up all carpet in my 88 4runner and put herc..liner down and it has not come up anywhere.
shane,88 toyota 4runner, v6, 5spd, 31x10.5x15 pro comp mudders, pacer wheels, flowmaster exaust, cold air intake.
Re: Herculiner Question [Re: toyotateen88] #827690 08/08/07 07:43 PM
Dieselshop Offline
[img]http://www.putfile.com/pic.php?img=6245600[/img]
go to your local paint supply place and ask for a reust adhibitor excuse my speelling, then just spray the rusted areas and prime then use your bed liner spray.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6383 MB (Peak: 0.7609 MB) Data Comp: Off Server Time: 2026-05-29 15:33:26 UTC
