96 trooper AC/ HEAT relay #827816 07/30/07 11:07 PM
therooster13 Offline OP
Anyone know where the AC/HEAT relay is in a 96 trooper Chilton's, shows it in the wire diagram but doesn't have it listed in fuse/relay locations <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: 96 trooper AC/ HEAT relay [Re: therooster13] #827817 07/31/07 01:14 AM
JLEMOND Offline
IT IS UNDER THE DASH ON THE LEFT KICK PANEL IN THE FUSE BOX JERRY
Re: 96 trooper AC/ HEAT relay [Re: JLEMOND] #827818 07/31/07 02:05 AM
all that is there is the fuse box and the accessory relay, and that is all the manual shows as being there
Re: 96 trooper AC/ HEAT relay [Re: therooster13] #827819 08/01/07 12:40 AM
JLEMOND Offline
THEN YOUR MANUAL IS WRONG , THERE IS SUPPOSSED BE AN AC HEAT RELAY IN THE FUSE BOX UNDER THE DASH ON THE LEFT KICK PANEL, IF I COULD FIGURE OUT A WAY TO GET THE PIX FROM THE MANUAL THAT I HAVE I WOULD POST IT , IT IS THE FACTORY WIRING MANUAL AND THE PIX IS AS CLEAR AS CAN BE , THERE ARE THREE RELAYS IN A ROW THE ONE CLOSEST TO THE FRT LEADING EDGE OF THE FUSE BOX IS FOR THE REAR DEFOGGER THE MIDDLE ONE IS FOR THE PWR WINDOW AND THE ONE CLOSEST TO THE DOOR EDGE IS FOR THE HEATER /A.C CONTROL., THERE IS A SMALL DIODE BETWEEN THE RELAY AND THE OUTER EDGE , JERRY
Re: 96 trooper AC/ HEAT relay [Re: JLEMOND] #827820 08/01/07 03:25 AM
Thanks for you help jerry dont know if you saw my other post on planetisuzu but I found out that there are 4 a'c realys on my troop, one driver fuse panel, one near blower motor, and two in engine fuse/relay box, I found one bad relay under hood at location K in the relay chart not sure if it is a ac relay but it is bad so worth a shot <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: 96 trooper AC/ HEAT relay [Re: therooster13] #827821 08/02/07 04:44 AM
JLEMOND Offline
YES THAT IS CORRECT, THERE ARE 4 TOTAL RELAYS, BUT THE ONE DESIGINATED A.C AND HEAT WHICH IS THE MAIN ONE IS THE ONE UNDER THE DASH, WHY THEY LABEL THEM THIS WAY IS ANY ONES GUESS, BECAUSE THE OTHER ONES CONTROL THE COMP, AND ONE OF THEM CONTROLS THE BLOWER MOTOR , GLAD YOU GOT IT LOCATED , BUT PLEASE GET YOURSELF A GOOD ISUZU ELECTRICAL MANUAL, IT WILL SAVE YOU A TON OF HEAD ACHS JERRY OH JUST SO HAPPENS I KNOW WHERE YOU CAN GET ONE FOR A GOOD PRICE..
Re: 96 trooper AC/ HEAT relay [Re: JLEMOND] #827822 08/02/07 09:17 AM
I might take you up on that offer what are ya looking to get for it?<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> Hoping to get lucky with the relays, found a 95 troop at a local junkyard going to strip as many relays off of it as I can today, built a little tester so I should be ok, hopefully I can get a fuse relay box cover with a label on it too
Re: 96 trooper AC/ HEAT relay [Re: therooster13] #827823 08/03/07 01:26 AM
JLEMOND Offline
35.00 POSTAGE PAID TO THE U.S. JERRY
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6182 MB (Peak: 0.6964 MB) Data Comp: Off Server Time: 2026-06-22 06:12:51 UTC
