2001 v 6 rodeo #827842 07/31/07 01:55 AM
tobeornottobe Offline OP
hi all im looking at buying a 2001 rodeo auto v6 89300k miles. test drove it and on first acceleration it sounded like there was wind noise or a fan running..is that possible....? it runs great and is not a whinning or groaning.. just like a wind noise...shifts great and smooth ...it has a sealed tranny any comments on them would be appreciated as i know nothing about them. is pretty good deal so am very close to buying it.
thanks again all
update
ok so no words of wisdom...going for another drive today and put it on a hoist to take a look...
Re: 2001 v 6 rodeo [Re: tobeornottobe] #827843 08/03/07 03:56 PM
NATO308 Offline
Great vehicles. At 89k miles, it is time to change the timing belt.
'94, and '00 Amigos and '00, 01 Rodeos. Rodeo springs and aftermarket 'hard top on 94. Aisin hubs OME 919's on the 2000 Amigo. 2000 and 2001 Rodeos have OME 912's and Aisin. Smoother ride with the OME 919's???
Re: 2001 v 6 rodeo [Re: tobeornottobe] #827844 08/03/07 08:38 PM
TrailMystic Offline
Sometimes the engine fan can be loud. Is that what you heard? The '01 is a great truck. Timing belt failure is non-destructive, so the engine doesn't power through itself for lunch if it breaks. It may need more oil than other engines due to an issue with the oil ring on the piston, but it is no big deal. Take care of the engine and it will last 300K. The other issue is the intake manifold gasket, which sometimes leaks. But replacement is not too expensive or difficult. The only other issue is the gas tank fuel sending unit, which is also not too big a deal to replace. Overall, there are no issues that should prevent you from buying an '01 Rodeo, just a few things to be aware of down the road.
Pete
'01 Rodeo Sport, 5 Speed Softie, Indy 4X rocker bars, OME 912's, Rancho 9000X's, Superwinch hubs, custom tube bumper with Warn 9000i , Flowmaster 50, TeraLow t-case gears, ARB front & rear lockers, TrXus MT's, Sway bar disconnects
Re: 2001 v 6 rodeo [Re: tobeornottobe] #827845 08/04/07 03:02 AM
Gizzy42 Offline
Its not actually sealed, just doesnt have a dip stick. It has drain and fill plugs. Search here or planetisuzoo.com for procedures on how to service and check fluid in them.
The 4L30E trans is kind of a weak link in the isuzus, but when properly maintained it can last a very long time. They just dont like to be neglected. The myth that its a sealed tranny is the biggest culprit.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: 2001 v 6 rodeo [Re: Gizzy42] #827846 08/05/07 07:49 AM
NATO308 Offline
The 4l30E tranny has two items that will start leaking, the accumulator piston cover and the shifter linkage seal. Both are fairly easy to repair. Buy the shifter seal on line and the piston cover from transmissionpartsusa.com. At the mileage listed, I would go ahead and get pan gaskets and a filter from transmissionpartsusa.com, they have the OEM style hard gaskets instead of cork or soft rubber found at Auto zone and ORiley's.
Re: 2001 v 6 rodeo [Re: TrailMystic] #827847 08/07/07 09:54 PM
ok thanks for the info....might be the fan that i hear but it stops at around 40 mph..i had a code reader put on it and it came back with the fuel sending unit code thingy...that means pulling the fuel pump right?..
thanks again really appreciate the info
Re: 2001 v 6 rodeo [Re: NATO308] #827848 08/07/07 10:00 PM
thanks.i had heard or read that getting the transmission flushed...where they hook up hoses and pump fluid in and out can cause problems ( loosen sludge or particals) am i correct or am i just making that up?.lol would it be better to just drop pan and drain oil out?
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6176 MB (Peak: 0.6928 MB) Data Comp: Off Server Time: 2026-11-03 04:52:41 UTC
