HELP - No start unless I play with the auto shifter #827935 07/31/07 05:14 PM
KarlC Offline OP
My 1990 V6 Montero will not start unless I play with the shifter. When in park I must move the shifter back until I hear a click and then she will start. Also the other night I had a load of tile in the back and parked on a bit of an incline and it would not start at all. I finally wiggled the shifter real hard while turning the key and got her to start. Any thoughts on this problem ?? Thanks
San Diego CA
Re: HELP - No start unless I play with the auto shifter [Re: KarlC] #827936 07/31/07 05:48 PM
justice Offline
Sounds like your nuetral safety switch is bad(only alows truck to be started in park or nuetral). I've never replaced one so I'll let some one more knowlegable chime in. should not be to difficult a repair.
Re: HELP - No start unless I play with the auto shifter [Re: KarlC] #827937 07/31/07 05:51 PM
8
89IsMine Offline
While I don't have an auto tranny, if I recall correctly there is an interlock switch that is supposed to prevent starting the engine if the vehicle isn't in park or neutral. Can you start it in neutral? I suspect the switch is either mis-adjusted or has gone bad. Use the search function, put in "neutral safety switch" (include the double quotes), select newer than 5 years and choose the Mitsubishi 4X4 & SUV tech and Mitsubishi Archive forums, and read through the posts that the search engine returns to you.
Good luck!
Eric W.
Re: HELP - No start unless I play with the auto shifter [Re: 89IsMine] #827938 07/31/07 07:22 PM
4xmonty Offline
neutral switch info
Check this out Karl <img src="/forums/images/graemlins/kewl.gif" alt="" />
Russ <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
GETTIN OLD THATS EARNED
Happy trails to you
(1)98 Montero SR RB Rock Crawlers BFG 33s Rancho 9000's OME Med coils rear
(2)95 4Runner All Pro Nerf bars BFG 32s
ARB bull bar
Downey 2" rear coils Downey headers
(3) 90 Montero LWB 3.0 auto
(4) 98 Kawi GPZ1100
Re: HELP - No start unless I play with the auto shifter [Re: 4xmonty] #827939 07/31/07 08:11 PM
StockRaider Offline
remove the center plastic covering shifter. unscrew the switch and slide it back just a hair, if its dirty clean it. just over the 20 years of it being on the planet the shifting into park moves the switch ever so slightly. <img src="/forums/images/graemlins/cheers.gif" alt="" />
EDIT: Also, if you clean the switch up, reapply dielectric grease to the leads. prevents the copper from going green. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: HELP - No start unless I play with the auto shifter [Re: StockRaider] #827940 07/31/07 09:02 PM
don Offline
Try starting with the A/T in N as well.
But it definately sounds like the safety switch.
As the truck ages, the shifter notch track also wears, and elongates the slot it rides in. This will let the shifter move out of the range of the safety switch, and make the switch look bad. The switch's position is adjustable, so first check if it's simply moved out of alignment...
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
Re: HELP - No start unless I play with the auto shifter [Re: don] #827941 07/31/07 09:44 PM
KarlC Offline OP
Thanks guys !!! It looks like I've got another little project to do.
San Diego CA
Re: HELP - No start unless I play with the auto shifter [Re: KarlC] #827942 07/31/07 10:08 PM
StockRaider Offline
project for me was 5 mins. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Richard E
1983 Honda XL600R
Re: HELP - No start unless I play with the auto shifter [Re: StockRaider] #827943 08/01/07 11:01 PM
KarlC Offline OP
So she did it again today at lunch in a parking lot. I tryed every thing to bring her to life but she would not start. So will 1 screw driver and a napkin it did the fix, and she started right up !!! Thnaks guys !!!
San Diego CA
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6264 MB (Peak: 0.7297 MB) Data Comp: Off Server Time: 2026-06-09 21:53:43 UTC
