2001 rodeo code #828019 08/01/07 12:59 PM
tobeornottobe Offline OP
ok took the 01 rodeo to autozone they did a code check and it came back with fuel tank sending unit needs replacing....i assume this is fuel pump ....or could it be fuel filter??? im going to buy this truck.......cross my finger and hope it lasts as long as my 88 trooper...any recommendations on what i should do or check when i get the keys???
thanks
Re: 2001 rodeo code [Re: tobeornottobe] #828020 08/01/07 02:30 PM
Richard Saylor Offline
Does the gas gauge work? Sounds like that's what's bad ... or coming up with that code. Generally, fuel pumps are either good or bad, as in either they work or don't. There's not much in between with them.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: 2001 rodeo code [Re: Richard Saylor] #828021 08/01/07 02:57 PM
well they say it has jumped around on gauge a couple times and it does not go down when you turn off key.
Re: 2001 rodeo code [Re: tobeornottobe] #828022 08/01/07 03:05 PM
Not sure on that particular model, but not all fuel gauges are zero return gauges. Some stay where the level was last indicated when the key was on.
84 Honda XL185S
Re: 2001 rodeo code [Re: tobeornottobe] #828023 08/01/07 03:35 PM
TrailMystic Offline
Common issue with our model. I had my fuel tank sending unit replaced under warranty at about 75K. There are lots of discussions of this on past threads. It was annoying not knowing how much fuel was in my tank, but mostly it showed empty when there was still a half tank remaining. The actual fuel pump is probably OK, but generally the pump and sending unit are replaced as an assembly. Do a search and read on whether you can replace the sending unit only on a '01. It is covered under the powertrain warranty if your warranty still applies.
Pete
'01 Rodeo Sport, 5 Speed Softie, Indy 4X rocker bars, OME 912's, Rancho 9000X's, Superwinch hubs, custom tube bumper with Warn 9000i , Flowmaster 50, TeraLow t-case gears, ARB front & rear lockers, TrXus MT's, Sway bar disconnects
Re: 2001 rodeo code [Re: TrailMystic] #828024 08/01/07 04:01 PM
no warranty here....will do some checking around and check the wires for lose connections and such....btw does your guage go to empty when key is turned off??
thanks
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6111 MB (Peak: 0.6812 MB) Data Comp: Off Server Time: 2026-11-03 17:44:41 UTC
