Tire pressure? #828138 08/01/07 11:38 PM
Grasscat Offline OP
I've been back up here in Tahsis, on the Island of Vancouver, BC, CA., since the first of July. Doing a lot of fishing and prawning. There are tons of logging roads to travel. What tire pressures do most of you run when playing on these roads? Most are in good shape, but have areas with washboard surfaces. IÆm running 28lbs in the front and 32lbs in the rear. This gets a little ruff at time. Tires are Pirelli Scorpion 31 x 10.59. These are great tires; most everyone has had a flat or two but not these. HereÆs a
few picÆs of the buggy, notice the truck bed liner paint below the door trim. I have more than half a can left for you Ray (offroader).
[Linked Image] Sign leaving Tahsis
some of the good road outside of town it soon get worse
Tahsis inlet
The black pipe? rod holder, works great. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael j
TreadLightly! Trainer
Re: Tire pressure? [Re: Grasscat] #828139 08/02/07 01:54 AM
Do you carry an air compressor? I would caution against going too low if you are without a reinflation means or are far from such items. When I've aired down for haul roads, I've gone to 15 psi with BFG AT's.
Nice pics! I miss fishing!
Re: Tire pressure? [Re: Grasscat] #828140 08/02/07 09:32 PM
RichSmith Offline
I'm just south of you in western Washington State where the gravel road conditions are similar to Vancouver Island. You don't have deep silt or sand, so you shouldn't need low pressures at all. But, you DO have many surprising potholes and rock protrusions in the hard gravel surface.
Your probably running the gravel roads between 20 mph and 50 mph most of the time (not crawling or off-roading), so I suggest reversing your tire pressures to run 32 front and 28 year. A softer tail should help your handling quite a bit.
Rich Smith
Re: Tire pressure? [Re: RichSmith] #828141 08/03/07 02:35 AM
Grasscat Offline OP
Thanks for the information Rich, I'll give it a try.
Russell, I was thinking of just a few pounds as I have no air supply. A CO tank is on the list of things to get, I'm sure you know how that goes.
Michael j
Re: Tire pressure? [Re: Grasscat] #828142 08/03/07 02:57 AM
FrankR Offline
Nice looking truck - I like the bedliner. <img src="/forums/images/graemlins/kewl.gif" alt="" />
If you have an inverter that will run it, this is a decent inflator for not too much money:
Craftsman
I run mine with a 400w (800watt peak) inverter.... it works very well and doesn't take too long to fill all four tires.
Frank
Re: Tire pressure? [Re: Grasscat] #828143 08/03/07 01:13 PM
toddstidham1 Offline
I bought a yellow heavy duty 12v air pump from Pep Boys about 2 years ago. It's all metal, pretty well constructed and fills tires plenty fast (2-3 minutes from 15 psi to 32). Cost $40 and has paid for itself many times over already. The yellow one has a standard 12v cigarette power plug on it, the also have an even heavier red one that only has battery clamps on the power leads. It's made by Master Flow.
-Todd
1987 Montero 2.6l 5-speed (Sold...but I still miss her)
2008 Jeep Patriot Sport 4x4
Re: Tire pressure? [Re: toddstidham1] #828144 08/03/07 04:03 PM
stony-man Offline
Isn't the red one from Pep Boys the one that was used in a shootout against ARBs compressor? If so, it performed great in the tests. Wish we had a Pep Boys around here.
Re: Tire pressure? [Re: stony-man] #828145 08/03/07 04:14 PM
hazy_daze Offline
There's a Pepboys down the street from me. Let me know which one you want, I'll get it and send it you.
On your dime of course <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Tire pressure? [Re: hazy_daze] #828146 08/03/07 05:29 PM
stony-man Offline
I need to see if I can find that post...I'd hate to get the wrong one. Thanks for the offer!! I might take you up on it. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Tire pressure? [Re: stony-man] #828147 08/03/07 07:00 PM
4xmonty Offline
This is an excellant compressor alot of us use it.I got mine at Kragens and CAP510 got his at Costco. Amazon
carries it too.Just look around do a search on the internet
and you should be able to find where you are.
MV50 <img src="/forums/images/graemlins/kewl.gif" alt="" />
compressor comparison
Russ <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
GETTIN OLD THATS EARNED
Happy trails to you
(1)98 Montero SR RB Rock Crawlers BFG 33s Rancho 9000's OME Med coils rear
(2)95 4Runner All Pro Nerf bars BFG 32s
ARB bull bar
Downey 2" rear coils Downey headers
(3) 90 Montero LWB 3.0 auto
(4) 98 Kawi GPZ1100
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6452 MB (Peak: 0.7712 MB) Data Comp: Off Server Time: 2026-06-07 05:53:21 UTC
