Page 1 of 3 1 2 3
solid axle conversion question #828308 08/02/07 06:07 PM
raiderquest Offline OP
Has anyone done a solid front axle conversion on their swb? If so what axle assembly is most common to use. In the archives I found the genII conversion but nothing for the swb. Any thoughts or ideas.I am trying to see if this conversion is worth the effort,time and expense.
Re: solid axle conversion question [Re: raiderquest] #828309 08/02/07 07:37 PM
Oyaji_Jon Offline
Mine is in the process o getting a Dana 44. There is no "common" axle as SAS on these isn't very common. Lots of axle choices out there...
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: solid axle conversion question [Re: raiderquest] #828310 08/02/07 07:47 PM
So which D44 are you using? More detail please....
Re: solid axle conversion question [Re: raiderquest] #828311 08/02/07 08:06 PM
sparkem Offline
Jeep Waggy driver drop d44 with matching 6on5.5 lug pattern. Frank in AUS i think got a Toyota axle re-tubed to driver drop. You can flip a Toyota PU axle too, with some work.
Look for Landraider on here, leeraider did one too. Monty90 maybe, was that his name? Couple others.
Re: solid axle conversion question [Re: raiderquest] #828312 08/02/07 08:07 PM
LandRaider Offline
Well. you'd do good to search using the term "SAS".
You could also search through all my posts.
Also LeeRaider is a good name to search under.
Most all of us that have DIY'd a SAS used a Wagoneer Narrow Track Dana 44.
Re: solid axle conversion question [Re: LandRaider] #828313 08/02/07 08:08 PM
LandRaider Offline
Thank you Sparky. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: solid axle conversion question [Re: LandRaider] #828314 08/02/07 08:34 PM
Hey, when did you get promoted to Mod? <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
On your SAS, did you "have" to change your steering to make things work, or was that a preference?
Re: solid axle conversion question [Re: MontyMcV] #828315 08/02/07 10:37 PM
LandRaider Offline
Yeah I had to put in a GM steering box. The mitsu box was a POS, and too small for the GM pump that I was running. I had problems with it boiling PS fluid before my sas. <img src="/forums/images/graemlins/scared.gif" alt="" />
Now I've got a big OLE saginaw steering box. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: solid axle conversion question [Re: LandRaider] #828316 08/03/07 01:22 AM
Oyaji_Jon Offline
Yep, I'm running front and rear Waggy 44s.
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: solid axle conversion question [Re: Oyaji_Jon] #828317 08/03/07 04:56 AM
bigroxydog Offline
I want one of those on my 88SWB what years should I look for to find the right Waggy 44?
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6396 MB (Peak: 0.7627 MB) Data Comp: Off Server Time: 2026-06-10 07:23:03 UTC
