noisy fuel injectors #828418 08/02/07 11:38 PM
dirtybikez Offline OP
Well ever since i bought my 88 runner 3.0 v-6 there has been a slight ticking noise coming from the engine but never though anything of it. Although recently the ticking has gotten slightly louder and so i looked more into the problem with a stethoscope and found that the fuel rail is makeing a loud ticking noise...
I have an idea that mabe a fuel injector is stuck open...
Can anyone help?
Re: noisy fuel injectors [Re: dirtybikez] #828419 08/03/07 07:48 AM
Snowtoy Offline
Loud injectors are a common/normal Toyota idiosyncracy, they may get louder with age, but I don't think a stuck one would be the cause of them getting louder. With the age of the truck, it would be a good idea to pull all of the injectors and have them cleaned and rebuilt. You should be able to find a shop there in Fremon or San Jose that can do it. The place I use in Sacramento charges $32/injector to clean/rebuild/balance.
If you pull them yourself, be caerful not to disturb the knock sensor wire, it gets brittle due to the heat and will break on you. You might also want to replace(relocate) the PCV valve as well. If you have a shop do the work, you should have them adjusted(shimmed) valves since the upper intake has to be removed to do the valves.
Re: noisy fuel injectors [Re: Snowtoy] #828420 08/04/07 08:08 AM
Davepet Offline
I used :
http://www.witchhunter.com/
$17/ injector + shipping to/from Washington.
I sent them out on a Saturday & had them back on Tue or Wed.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5927 MB (Peak: 0.6463 MB) Data Comp: Off Server Time: 2026-05-29 18:24:56 UTC
