head leaking oil!!! *DELETED*
#828583
08/04/07 07:05 AM
Post deleted by AkFordMan
Re: head leaking oil!!!
[Re: AkFordMan]
#828584
08/04/07 07:14 AM
I would suspect its the round caps on the back of your cam shaft (the exact name escapes me) . They usually come with the valve cover gasket sets. I have always been worried that would happen with one of my vehicles. Easy enough to fix though.
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: StockRaider]
#828585
08/04/07 04:00 PM
I agree with stockraider. Try to degrease that area of the engine and then use a small mirror to look back there. Run the engine and look where the leak is coming from.
-Todd 1987 Montero 2.6l 5-speed (Sold...but I still miss her) 2008 Jeep Patriot Sport 4x4
[Re: toddstidham1]
#828586
08/05/07 02:22 AM
Well, Ihave removed the exhaust manifold on the passenger side to get abetter look at my leak.Oil just runs out at steady stream , in the middle of the head,bottem part of head. Were the head gasket goes..It is leaking,running out between head & the block. Is this posible or Am I seeing things.
[Re: AkFordMan]
#828587
08/05/07 02:52 AM
With the engine cool, reach behind the head and use your finger to feel at the bottom edge of the valve cover. Your finger SHOULD NOT be able to penetrate anywhere. If it can, then you are missing the half moon gasket that someone else mentioned up above. Also, feel along the back side of the head and ensure that the round plug is in place right in the middle of the back face.
These two things will cause your top end to PUKE oil like you are dedscribing. You are probably seeing where the oil is running along the edge and down the block.
I hope this helps you find your problem...
73 -Jon KJ6GVM As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter Grampa's Trooper 1974 FJ40 1987 FJ60
[Re: Oyaji_Jon]
#828588
08/08/07 06:22 PM
What happened? Did he fix it?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6113 MB (Peak: 0.6815 MB) Data Comp: Off Server Time: 2026-06-20 22:18:37 UTCValid HTML 5 and Valid CSS
