head leaking oil!!! *DELETED* #828583 08/04/07 07:05 AM
A
AkFordMan Offline OP
Post deleted by AkFordMan
Re: head leaking oil!!! [Re: AkFordMan] #828584 08/04/07 07:14 AM
StockRaider Offline
I would suspect its the round caps on the back of your cam shaft (the exact name escapes me) . They usually come with the valve cover gasket sets. I have always been worried that would happen with one of my vehicles. Easy enough to fix though.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: head leaking oil!!! [Re: StockRaider] #828585 08/04/07 04:00 PM
toddstidham1 Offline
I agree with stockraider. Try to degrease that area of the engine and then use a small mirror to look back there. Run the engine and look where the leak is coming from.
-Todd
1987 Montero 2.6l 5-speed (Sold...but I still miss her)
2008 Jeep Patriot Sport 4x4
Re: head leaking oil!!! [Re: toddstidham1] #828586 08/05/07 02:22 AM
A
Well, Ihave removed the exhaust manifold on the passenger side to get abetter look at my leak.Oil just runs out at steady stream , in the middle of the head,bottem part of head. Were the head gasket goes..It is leaking,running out between head & the block. Is this posible or Am I seeing things.
Re: head leaking oil!!! [Re: AkFordMan] #828587 08/05/07 02:52 AM
Oyaji_Jon Offline
With the engine cool, reach behind the head and use your finger to feel at the bottom edge of the valve cover. Your finger SHOULD NOT be able to penetrate anywhere. If it can, then you are missing the half moon gasket that someone else mentioned up above. Also, feel along the back side of the head and ensure that the round plug is in place right in the middle of the back face.
These two things will cause your top end to PUKE oil like you are dedscribing. You are probably seeing where the oil is running along the edge and down the block.
I hope this helps you find your problem...
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: head leaking oil!!! [Re: Oyaji_Jon] #828588 08/08/07 06:22 PM
Oyaji_Jon Offline
What happened? Did he fix it?
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6103 MB (Peak: 0.6805 MB) Data Comp: Off Server Time: 2026-06-17 10:48:13 UTC
