88 4runner died and wont start. help???? #828761 08/05/07 02:51 AM
toyotateen88 Offline OP
ok my 88 4runner died while i was running down the road at 55mph. it will turn over but wont start. im gettin power to the coil from igniter but the coil wire will not spark. i changed coil and still got the same thing...any ideas appreciated.
shane,88 toyota 4runner, v6, 5spd, 31x10.5x15 pro comp mudders, pacer wheels, flowmaster exaust, cold air intake.
Re: 88 4runner died and wont start. help???? [Re: toyotateen88] #828762 08/05/07 03:16 AM
is a resistor and ignitor the same thing????? for a coil???
Re: 88 4runner died and wont start. help???? [Re: toyotateen88] #828763 08/05/07 09:44 AM
Davepet Offline
Nope. An ignitor is an electronic ignition package, a resistor just drops the voltage on a 12v system to around 6 volts.
You should check your sending unit in the distributor (FSM has the tests) to see if it's working properly.
Dave
Re: 88 4runner died and wont start. help???? [Re: toyotateen88] #828764 08/05/07 01:40 PM
toyrunner Offline
pull the distributor cap and see if the rotor is turning...
also check the wires that run from the coil to the injectors. that is the bundle that runs across the engine, over the exhaust manifold. most of these I have seen are brittle and crack from the heat easily <img src="/forums/images/graemlins/scared.gif" alt="" />
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: 88 4runner died and wont start. help???? [Re: toyrunner] #828765 08/05/07 03:07 PM
missouriman Offline
might be the timeing chain.
if the rotor is not turning, chain is gone.
Re: 88 4runner died and wont start. help???? [Re: toyotateen88] #828766 08/05/07 04:32 PM
ZUK Offline
A friend of mine had the same happen...going down the road and it died.....just like as if someone turned off the ignition key. Turn over but no fire. Neither he or I could believe it was the FP because we both know that the Totota FP last just about forever....well, it turns out the previous owner put in a cheapy after-market POS FP and it really did go bad. All fixed after a new one....a genuine one <img src="/forums/images/graemlins/wink.gif" alt="" />
first, you need to determine if it's a gas or spark issue....figure out a way to inject some fuel into the plenum without removing the air intake hose. AI Hose must stay connected for FP to stay energized.
mostly stock
Re: 88 4runner died and wont start. help???? [Re: ZUK] #828767 08/06/07 05:51 AM
well i took off the dist. cap and the rotor button did not turn. so does that mean it is 100% the timing chain. how much does that cost to have fixed?
Re: 88 4runner died and wont start. help???? [Re: toyotateen88] #828768 08/06/07 06:38 AM
kewlynx Offline
Your next step is a visual inspection.
http://www.4x4wire.com/toyota/maintenance/timingchain/
Got any tools/skills? We're here if you're a-willin'.
At this point, the valve cover is to be removed to take a look-see. There's a half-moon gasket on the front of the head. There's also one on the back of the head, so make sure you don't lose them.
The 22Rx is an interference engine, so hopefully you got lucky and didn't clang the pistons with the valves.
ALSO, if the timing chain shot, there WILL be parts in the oil pan, which will need to come off and cleaned out. A flush will NOT do, as the drain plug boss stands up enough to where there is still about a 1/2" or so of oil still in the pan when you drain it.
**ubi apis- ibi salus**
Re: 88 4runner died and wont start. help???? [Re: kewlynx] #828769 08/06/07 09:33 AM
Adam F Offline
Kewlynx, his sig says he has a V6, so the good news is its a non-interference and a timing belt. Easy fix. No damage done to the engine.
97 4R, stock, daily driver
Re: 88 4runner died and wont start. help???? [Re: kewlynx] #828770 08/06/07 06:21 PM
casper3t Offline
Kinda off topic a bit.
What happens when the piston when they're not replace when it is damage by the valves hitting it?
Thomas
94 Toyota Pickup 22R-E
EB's Street RV Head with 268* Cam
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6418 MB (Peak: 0.7672 MB) Data Comp: Off Server Time: 2026-05-29 21:10:09 UTC
