no spark
#828823
08/05/07 04:26 PM
I have a 83 cj-8 with the 258. I was getting off the interstate and it backfired and died. It will not start now. I replaced the timing chain. I replaced the coil, cap, rotor, pick-up coil, and had the ignition module checked.(it works) I checked the spark plug leads and no spark. Any ideas?
Re: no spark
[Re: nj8]
#828824
08/05/07 05:21 PM
None of the above can work without electricity! Got any? The ignition module (spark Box) is only bout 20 bucks.. I didn't know there was a test for them. Golly sounds like you started throwing parts at a problem that should have been better diagnosed first. Make sure all the wiring is correct and check the COIL wire for spark. There are a LOT more sparks there and it is easier to see the spark. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: no spark
[Re: nj8]
#828825
08/05/07 05:22 PM
None of the above can work without electricity! Got any? The ignition module (spark Box) is only bout 20 bucks.. I didn't know there was a test for them. Golly sounds like you started throwing parts at a problem that should have been better diagnosed first. Make sure all the wiring is correct and check the COIL wire for spark. There are a LOT more sparks there and it is easier to see the spark. Could be a bad coil wire started all your problems. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: no spark
[Re: BigJim]
#828826
08/05/07 05:35 PM
You are most likely right about throwing parts at the problem. I do not have power to my gauges. Is that a result of the ignition module?
Re: no spark
[Re: nj8]
#828827
08/05/07 06:21 PM
NO! That would be akey--ignition problem not sending 12v to the ignition also. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: no spark
[Re: BigJim]
#828828
08/05/07 06:27 PM
My control module and coil are getting hot when turning the key on.
Re: no spark
[Re: nj8]
#828829
08/06/07 12:25 AM
My Cj7 85 did the same thing. I blew a fuse did you check them. It was a shorted wire that cause the fuse to blow. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: no spark
[Re: Greg2000]
#828830
08/12/07 05:03 AM
My Cj7 85 did the same thing. I blew a fuse did you check them. It was a shorted wire that cause the fuse to blow. <img src="/forums/images/graemlins/smile.gif" alt="" /> I have expeirenced the same problem with an 85.The wiring harness on the fender rubbed through and burned a fuesible link I think by 83 Amc was using a fusible link inline to the coil or ignition box, dont remember which.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6187 MB (Peak: 0.6967 MB) Data Comp: Off Server Time: 2026-06-13 10:54:02 UTCValid HTML 5 and Valid CSS
