3.0 timing belt question #828950 08/06/07 03:28 AM
Texrok Offline OP
I did a little search on here first to try to find answers but everything seems to be for a 22r. I have a 1994 with a 3.0 and 144K miles. What is considered normal routine maintanance for timing belt replacement?
Does this truck have a timing belt or a timing chain?
Thanks for any help.
Re: 3.0 timing belt question [Re: Texrok] #828951 08/06/07 03:34 AM
kewlynx Offline
Belt. Same for the 3.4
http://www.4x4wire.com/toyota/maintenance/timing_belt/. R&R is similar.
Also check out the maintenance interval for the Tacomas, also in our Toyota section above in the header. Methinks it's 60K for those.
**ubi apis- ibi salus**
Re: 3.0 timing belt question [Re: Texrok] #828952 08/06/07 08:17 AM
Snowtoy Offline
Every 80k, so you are either good for a couple of 15k, or long over due. I would take/call the vin# into the dealer and see when/if the HG recall was done. There is a good chance the t-belt was changed at that time.
If you haven't had the truck for a couple of yrs, you should also check to see if the steering relay rod recall has also been done on the truck. From what I can tell the notice of the recall only went out to original purchasers, or those who purchased ithe vehicle through a Toyota dealer. I recieved the notice for my '90(which I bought new), but not the '91 I picked up a few yrs ago.
Re: 3.0 timing belt question [Re: Snowtoy] #828953 08/07/07 12:18 AM
Texrok Offline OP
OK good news. I talk to the former owner (my dad) and found out that he had the T-Belt changed at about 100k alond with the water pump and several other items. Looks like I'm off the hook for now. I think all the recalls have been done also. I know the steering rod recall has been done.
Thanks for the good info guys. This site rocks.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6040 MB (Peak: 0.6599 MB) Data Comp: Off Server Time: 2026-06-07 05:58:58 UTC
