TRD suspension taller then Non-TRD suspension? #828975 08/06/07 08:36 AM
Coyotekid Offline OP
Found this on Craigslist:
Stock Toyota Tacoma TRD suspension including rear leaf springs, and front coilovers with shocks 8K miles for $100.00
Seeing as I want to lift my Taco a little/increase the load capacity so she doesn't sag(as much) when I load her down with tools, and supplies, this caught my eye..And I need shocks too..reeeeallly bad LOL
Any thoughts? Eh? Eh? <img src="/forums/images/graemlins/shiner.gif" alt="" />
-Dano-
<img src="/forums/images/graemlins/rolleyes.gif" alt="" />
~~~The more People I meet, the more I like My Dog..~~~
-96' Tacoma 3.4 4x4 5 Speed, Trueflow intake+Deckplate, 2.5 inch Magnaflow Cat-back,OME 881's, and some extra-leaves in the rear..
-68' Chevelle Malibu..Stage one of Restoration: *Collecting funds* <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: TRD suspension taller then Non-TRD suspension? [Re: Coyotekid] #828976 08/06/07 04:57 PM
G
Greg_Canada Offline
The difference is the bilstein shocks instead of tokico's... thats all.
89 4Runner
Re: TRD suspension taller then Non-TRD suspension? [Re: Coyotekid] #828977 08/07/07 02:37 AM
BIGBURLYNAKEDMAN Offline
I always thought the TRD suspension was a bit stiffer. I know the ride height is the exact same, but I was under the understanding that it had greater load capacity. And, by the way, the Tokicos are the TRD equivalent for the 4-door model, not the stock model. The stock models have every day cheapy oil shocks.
I'd say that $100 is a damned good deal for TRD suspension with low miles. The new shocks alone would be worth at least $60 a pop.
'99 Tacoma Xtra cab V6 TRD
TRD Supercharged, URD 7th injector and 2.2" pulley, 32X11.5 BFG All-Terrains, OME 881 3-inch lift/Toytec AAL, 5100 Series Bilsteins all around, and ProComp 130 lights.
No I'm not some creepy naked guy...
Re: TRD suspension taller then Non-TRD suspension? [Re: Coyotekid] #828978 08/07/07 05:56 AM
T-Rex Offline
To my knowledge, there is no height difference. The major difference is in the better shocks, and the fact the coils are progressive. As for load, it'll be the same as the overall weight limit should be similar.
For the price, that would be a killer deal. Again, that's assuming you're replacing your older stock suspension coils and shocks. If you're looking for a lift, you'll need to look elsewhere.
02 Tacoma Double Cab TRD Prerunner .. just added 3" lift .. more to come
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6049 MB (Peak: 0.6609 MB) Data Comp: Off Server Time: 2026-05-29 14:42:40 UTC
