3.4 question #829032 08/06/07 05:36 PM
W
Will_I_Am Offline OP
I have noticed recently my 3.4 with a TRD charger has started to sip coolant from the coolant jug, have to fill it once a week, anybody with a blower ever had a head gasket leak on a 3.4?
William
William Gabay
Re: 3.4 question [Re: Will_I_Am] #829033 08/07/07 04:50 PM
speedlever Offline
IIRC, the 3.4's built until 1997 had a recall on the head gasket issue. Did yours get replaced under warranty? I think the leak was external and visible... but can't recall the details.
I had a 1996 Taco/3.4 that had to have the HG done. My 1998 T100 did not.
Someone here will know about this.
--speedy
White '98 T100 SR5 4x4 ExCab Auto - wrecked.
2008 Honda Ridgeline RTS replaced the T100.
Re: 3.4 question [Re: Will_I_Am] #829034 08/07/07 06:18 PM
adam Offline
If it had the recall done, I'd look somewhere else first before jumping to a worst case scenario. My post recall coolant leak ended up being an old block heater and a couple of hose junctions...just sipped it out so that I'd have to top up the reservoir every couple of months.
~Adam
Re: 3.4 question [Re: Will_I_Am] #829035 08/08/07 12:09 AM
W
Whizkidder Offline
No issues with my S/C (yet...!), now over 80,000 miles since installation.
My 3.4L did seep coolant out of both ends of both radiator hoses from the day it was new until I replaced the factory hoses with aftermarket ones from Advanced Auto (Gates, I think...). Good luck!
Re: 3.4 question [Re: Whizkidder] #829036 08/16/07 01:19 AM
W
Ok thanks guys, i will review the manual and look at all the possible leak areas.
Will
William Gabay
Re: 3.4 question [Re: Will_I_Am] #829037 08/16/07 04:01 AM
CJMT100 Offline
I have a replaced 3.4 from the head on down, doesnt sip coolant at all. About 45k on that engine too.
Re: 3.4 question [Re: CJMT100] #829038 08/16/07 03:30 PM
marion Offline
Could be your waterpump too. Mine leaked thru the gasket and I couldn't see the leak until I replaced it when I was doing the timing belt. But that sounds like a lot of coolant to be leaking externally without some obvious sign.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6147 MB (Peak: 0.6881 MB) Data Comp: Off Server Time: 2026-06-21 00:08:56 UTC
