bent axel #829120 08/06/07 09:05 PM
cktoy Offline OP
I was in a wreck today.My rear pas. wheel took the brunt of the hit,I think the axel is bent.Can these be repaired or straightened out
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: bent axel [Re: cktoy] #829121 08/06/07 09:33 PM
4Crawler Offline
Probably easier and less expensive to swap out the axle, either the shaft only or housing if it is bent. Justyard is one option, or I have a spare axle shaft or two:
- http://www.4crawler.com/4x4/ForSale/index.shtml#UsedParts
Re: bent axel [Re: 4Crawler] #829122 08/07/07 12:14 AM
cktoy Offline OP
thanks,I cant see any damage to anything outside,the wheel sits about 3/4" further back than it should.it drives ok .any good way to check the housing?
oh what a feeling:
84 supra yard art
Re: bent axel [Re: cktoy] #829123 08/07/07 12:32 AM
4Crawler Offline
Lift the tire in the air and spin it. If it wobbles, the axle is bent. If it is only shifted, my guess is a sheared off center pin and the axle and u-bolts slid off center of the springs.
Re: bent axel [Re: 4Crawler] #829124 08/07/07 01:09 AM
OOP'S Offline
Like Roger said, check the center pin in the spring. They are designed to shear on hard impact. If that is what it is, replace and torque the U-bolts down on both sides to 90 ft lbs.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: bent axel [Re: OOP'S] #829125 08/07/07 01:49 PM
cktoy Offline OP
thanks guys,this site is the best tool in the box
oh what a feeling:
84 supra yard art
Re: bent axel [Re: cktoy] #829126 08/08/07 03:14 PM
cktoy Offline OP
Im pretty sure my housing is bent.Anybody know where I can get another one.I just bought an 86 single cab with efi,but hate to tear it apart cause it runs good and only has 160k on it.MAN THIS SUCKS <img src="/forums/images/graemlins/angry.gif" alt="" /> it was a hit and run to top it off.it looks like the bend is in the very end of the housing ,theres no wobble when I spin the tire.the rear of my wheel sits 3/4" closer to the spring than the front.looks like the spring is bent too.the pin doesnt look to be sheered
oh what a feeling:
84 supra yard art
Re: bent axel [Re: cktoy] #829127 08/08/07 04:04 PM
Staceman Offline
Here you go dude. From car-part.com
I'm not sure if this is close to you in Tn or not.
Axle Housing Only
Toyota Truck -*UNDER *437-58042* 3318 $75 Bolivar Salvage & Auto Parts USA-TN(Bolivar) E-mail 1-800-748-9185 / 1-731-658-9468
1987
Axle Housing Only
Toyota Truck -*TRANS *437-58042* 3156 $75 Bolivar Salvage & Auto Parts USA-TN(Bolivar) E-mail 1-800-748-9185 / 1-731-658-9468
Re: bent axel [Re: Staceman] #829128 08/08/07 04:07 PM
Staceman Offline
Here's a few in the Carolinas.
Axle Housing Only
Toyota Truck 4X4,MT A 960042 $75 Roper Motor Company USA-NC(Grover) E-mail 1-704-739-1396 / 1-800-222-7931
1987
Axle Housing Only
Toyota Truck 4X4,BARE 060458 $75 Graves Auto Salvage USA-SC(Aiken) E-mail 1-803-648-9012 / 1-800-922-8849
Re: bent axel [Re: Staceman] #829129 08/08/07 05:48 PM
cktoy Offline OP
cool,boliver is not to farr to go for truck parts.THANKS
oh what a feeling:
84 supra yard art
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6437 MB (Peak: 0.7638 MB) Data Comp: Off Server Time: 2026-05-30 01:18:18 UTC
