dash removal #829337 08/07/07 10:17 PM
tobeornottobe Offline OP
hi ..i have a 2001 rodeo and the fan selector switch is broke if i pull it out and move it it will change speeds..otherwise it just flops around...i see two screws over the insturment panel(speedo) and thats all..is there a clip inbehind this or am i missing something? guy at the salvage said i have to buy the whole unit (75.00) is that correct?
Re: dash removal [Re: tobeornottobe] #829338 08/07/07 11:22 PM
TrailMystic Offline
I don't remember this problem ever coming up before in this forum. Usually you can buy the fan speed selector switch for a Japanese car without replacing the entire climate control unit. The fan speed selector can usually be unscrewed from the main climate control. Maybe someone can track down that part for you (I can't do it on this computer). I never had a need to access the Rodeo climate control, but generally with all cars you can get to the climate control by removing the center counsol and the radio. This gives you access to detach the cables and wires from the climate control so it can be slipped out.
Salvage climate control units may be guaranteed to work, but they can be pretty beat up. I think they take them out with a pry bar. You could always take out the fan speed selector and only use that part.
Pete
'01 Rodeo Sport, 5 Speed Softie, Indy 4X rocker bars, OME 912's, Rancho 9000X's, Superwinch hubs, custom tube bumper with Warn 9000i , Flowmaster 50, TeraLow t-case gears, ARB front & rear lockers, TrXus MT's, Sway bar disconnects
Re: dash removal [Re: tobeornottobe] #829339 08/07/07 11:47 PM
Gizzy42 Offline
HERE is a write up I did on installing glow gauges in my '99. The first part shows what all needs to be done to remove the bezel around the guages. It will be the same on the '01.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: dash removal [Re: Gizzy42] #829340 08/08/07 01:22 PM
Hey great........that helps alot...will pull it apart today and see what has happened.......thanks <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6000 MB (Peak: 0.6561 MB) Data Comp: Off Server Time: 2026-06-07 05:32:48 UTC
