Clutch replacement links? Other questions inside. #829679 08/09/07 12:19 AM
O
Omega Supreme Offline OP
My GF 93 4runner v6 needs a new clutch. I am going to do it, any write ups or DIY's? Thanks guys. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Clutch replacement links? Other questions inside. [Re: Omega Supreme] #829680 08/09/07 01:09 AM
kewlynx Offline
Check our Toyota section in the header above. We also have an FSM sticky'd in the early trucks section. <img src="/forums/images/graemlins/notooth.gif" alt="" />
**ubi apis- ibi salus**
Re: Clutch replacement links? Other questions inside. [Re: Omega Supreme] #829681 08/09/07 01:14 AM
Adam F Offline
Have you ever done a clutch before? If so, it's pretty straightforward. There are a few tricks, like packing the pilot bearing with grease, and fitting a bolt or metal rod in the center that it fits tight, and then hitting it with a hammer. This forces the grease out and pops the bearing out.
Rent a good tranny jack, and ratchet strap the trans to the jack.
Get a LONG (20" at least) extension, plus a few other various length extensions. And get a swivel socket adapter (Harbor Freight sells a set cheap) NOT a ujoint (the swivel limits travel, wont bind)
You should inspect and possibly get the flywheel resurfaced by a machine shop during the clutch replacement. When you take the flywheel off, inspect and possibly replace the rear main seal if it leaks at all (might even be a good idea to replace it even if it doesnt leak. )
Get a factory Asco clutch. They are around 120 at www.jtoutfitters.com call and specifically ask for an asco
97 4R, stock, daily driver
Re: Clutch replacement links? Other questions inside. [Re: Adam F] #829682 08/09/07 07:09 PM
O
thanks guys!!!
Re: Clutch replacement links? Other questions inside. [Re: Adam F] #829683 08/12/07 01:46 PM
OOP'S Offline
Great info except for this, it should read "You must get the flywheel resurfaced" Always have a flywheel resurfaced when you install a new clutch. I did not take my own advice once and was pulling the tranny the next weekend because of clutch chatter.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Clutch replacement links? Other questions inside. [Re: OOP'S] #829684 08/12/07 03:05 PM
Adam F Offline
I diddnt get my resurfaced and 2 years later its still fine.
Better safe then sorry though I guess.
Re: Clutch replacement links? Other questions inside. [Re: Adam F] #829685 08/15/07 05:52 PM
O
All good info,, Should i just buy a new flywheel as i will be short on time?
Re: Clutch replacement links? Other questions inside. [Re: Omega Supreme] #829686 08/16/07 03:45 AM
kewlynx Offline
Call the machine shop and see what their lag time is before you start. I'd prefer to know the one I got is properly done, rather than have an untouched one show up in the box.
Re: Clutch replacement links? Other questions inside. [Re: kewlynx] #829687 08/16/07 04:55 PM
O
I would but i am going to be in redlands California and i dont know of any good machine shops down there. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6294 MB (Peak: 0.7322 MB) Data Comp: Off Server Time: 2026-06-07 04:37:42 UTC
