NEED Part# fast ! #829690 08/09/07 12:33 AM
DC Offline OP
Ok.. I'm anable to find an add-a-leaf that will fit the sports rear leaf. Putting this in for the trip coming up. If yoiu guys know what will fit with a part number that would be great. I been doing a search for on the site to the past 7 years and can't find it yet. The trucks at the shop and the guys are just sitting there not knowing what to do.
Re: NEED Part# fast ! [Re: DC] #829691 08/09/07 07:28 AM
don Offline
Check the yellow pages for shops that make and install commercial truck leaf springs.
They can make them.
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
Re: NEED Part# fast ! [Re: DC] #829692 08/09/07 03:52 PM
justice Offline
Since the early leaf sprung Montero Sport is the same platform as the Mighty max, I would look at the part number for one of those, which probably interchanges with the leave sprung Gen 1 add a leaf. Check summitracing.com.
Re: NEED Part# fast ! [Re: justice] #829693 08/09/07 04:11 PM
justice Offline
Rancho makes one for a might max with 2.5 inch wide leafs..measure the width of yours if the same should work..could not find a pt# but any rancho dealer should be able to get it for you.
Re: NEED Part# fast ! [Re: justice] #829694 08/09/07 05:12 PM
hazy_daze Offline
In the Rancho Book: P/N RS60612
The listing is for 82-84 pickup, 2 and 4wd.
Specs: 22" length, 2.36" width, .40" thickness, 2" arch, Tapered ends.
Hope that helps <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: NEED Part# fast ! [Re: hazy_daze] #829695 08/09/07 06:30 PM
Spoke w/ Dat. He's checking it out today. He said the 4x4shop checked the spring arch of his springs and couldn't find a comparable arch in the book but I have to wonder how well they searched.
Re: NEED Part# fast ! [Re: off-roader] #829696 08/09/07 10:16 PM
DC Offline OP
I dont remember what they said the width of the springs were but the one on the market were either 1/4 too wide on both side or a 1/4 too shorth on bith side. With all the searching the did come up with OME for a a spring set.
So this is what i'm doing. They a a long leaf set that is 1/4 smaller on both side. I told to put it in. I believe with the longer set the 1/4 won't be much of a diff.
BTW the shop is 4Xdoctors. they are pretty well known for thye their work.
also glad to hear your gonna make it Ray.
DC
97Sport A/T 33's
locked front & rear 4.90
5" IFS Lift
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6188 MB (Peak: 0.6970 MB) Data Comp: Off Server Time: 2026-06-09 21:49:28 UTC
