water leak from firewall #829705 08/09/07 01:35 AM
rany Offline OP
im not sure this is the right place but i have a 89 4/4 king cab toyota pickup. for some reason im leaking water from what appears to be a hose going into fire wall,or some where from that area on the passengers side..now this drives me crazy but on a very hot day it be ok,nut than it will overheat just like that..one day its fine than it overheats...i changed the thermstat twice,radiator cap,and radiator was fixed cause of some holes..i think that is everything,, thanks for youre time
Re: water leak from firewall [Re: rany] #829706 08/09/07 02:08 AM
Dieselshop Offline
sounds like a heater core leak or hose going to heater core, is the leak green? if it is green it is probably the heater core, I have also seen ac leaks in the cab on hot days. hope this helps
Re: water leak from firewall [Re: rany] #829707 08/09/07 02:36 AM
kewlynx Offline
Welcome to the board! Sounds like your control valve is leaking where it enters the cab thru the firewall. IIRC, it's viewable looking up from beneath.
**ubi apis- ibi salus**
Re: water leak from firewall [Re: kewlynx] #829708 08/09/07 02:55 AM
Jake97T Offline
the A/C also drips water from the firewall if your talking about just water and not antifreeze...
Re: water leak from firewall [Re: Jake97T] #829709 08/09/07 03:24 AM
kewlynx Offline
True; haven't needed to turn mine on in awhile, tho' I should.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6068 MB (Peak: 0.6708 MB) Data Comp: Off Server Time: 2026-11-03 11:36:14 UTC
