Aftermarket fender flares? Good/Bad/Ugly? #829749 08/09/07 05:53 AM
dr_time Offline OP
What's everyones opinion on aftermarket fender flares? Any recommmended? Any brand to stay away from?
Re: Aftermarket fender flares? Good/Bad/Ugly? [Re: dr_time] #829750 08/09/07 09:43 AM
Snowtoy Offline
It depends on the generation rig you have, and the type of flare you want to run. IMO the Bushwacker cut-out fenders look best on the 2nd gen('84-'88) truck or 1st gen Runner('84-'89. While the Warn flares look better on the 3rd gen truck('89-95non Taco) or 2nd gen Runner('90-'95).
These are Warn flares on my '90.
In this 4x4wire Post, the owner has aftermarket front fenders with the cut-out style flares on the rear. The front cut-out flares are basically the same as the rear.
Run a search, there have been a few posts in the past about flares. You might also want to check the members photo section to see.
Re: Aftermarket fender flares? Good/Bad/Ugly? [Re: dr_time] #829751 08/09/07 01:23 PM
sirus027 Offline
x2 on the 1st gen 4runners. My '85 now doesn't have flares. I've heard that the b.w. pocket flares pop out or break off when they hit trees/rocks, but I never hit anything with mine on the '84 so I wouldn't know. Here's some pics.
my '84 4runner
other's rig
Re: Aftermarket fender flares? Good/Bad/Ugly? [Re: dr_time] #829752 08/09/07 03:39 PM
btn Offline
I have and like the Warns. They fit the contour of the sheetmetal well and come with the two-sided foam tape to seal to the sheetmetal. They add about 2 inches tire coverage.
1989 reg cab pickup, 22re, 31s, 4.56s, rear ARB, rear OME springs, RS9000s, otherwise stock.
Re: Aftermarket fender flares? Good/Bad/Ugly? [Re: sirus027] #829753 08/10/07 01:43 AM
CJM Offline
other's rig
are these warn ? or bushwacker ?
83 Trekker SR5
NEW Trekker forum
Re: Aftermarket fender flares? Good/Bad/Ugly? [Re: CJM] #829754 08/10/07 08:15 PM
Red_Chili Offline
Toyota Section Staffer
Bushwacker. Try as I could, there were no pix to be found of the Warns on a 80s Toy, and they don't make them for the 4Runner.
No cutting required for the rear (on a 4Runner, not so the truck), the fronts need it (but only where we usually do it so....
I am likely to go with these and color match it like Moomba did. Rocky Mountain Suspension lists the rears for $185 or so, while 4WPW is $215 <img src="/forums/images/graemlins/zombie.gif" alt="" />
[edit] nevermind, 4WPW matched the $185... <img src="/forums/images/graemlins/smile.gif" alt="" />
-Bill
Re: Aftermarket fender flares? Good/Bad/Ugly? [Re: CJM] #829755 08/11/07 04:30 AM
Snowtoy Offline
Yep those are Bushwacker's. I believe that BW's are the only style that use rivets to attatch to the side of the truck.
I found a listing for 2nd gens Warn flares at go Warn.com, but no pictures. I think this rig here has the Warn flares, they could be a set of BW's non-cut-out style flares, but I am pretty sure they are Warn.
IMO BW's cut-outs just seem to fit the 2nd gen styling better than any other type of fender flare.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6193 MB (Peak: 0.7114 MB) Data Comp: Off Server Time: 2026-07-13 23:57:15 UTC
