can any give some advise for an 22re? #829855 08/09/07 07:50 PM
metal2dirt Offline OP
i just did an motor swap in my 86 4runner. so i got the long block of ebay its one of the remanufactured block and new head ect. i got it all back together and running. it idle and reves like it should. but when i drive it has an real bad bog. it feels like ther something holding it back. does anyone have any trouble shooting tips for me. it whould be much appreciated.
Re: can any give some advise for an 22re? [Re: metal2dirt] #829856 08/09/07 08:53 PM
Staceman Offline
Timing needs advanced?
Is the distributor in right?
Re: can any give some advise for an 22re? [Re: metal2dirt] #829857 08/09/07 10:04 PM
RatLabGuy Offline
How many miles are on it since the complete rebuild?
It takes awhile for it to really build up to power (break-in time etc).
Question Reality.
Re: can any give some advise for an 22re? [Re: RatLabGuy] #829858 08/10/07 12:06 AM
about 60 miles.
Re: can any give some advise for an 22re? [Re: Staceman] #829859 08/10/07 12:08 AM
it tdc 0 degrees what should it be at?
Re: can any give some advise for an 22re? [Re: metal2dirt] #829860 08/10/07 12:47 AM
DanSweet Offline
might wanna double check your vacuum hoses too
94' 22re Ex Cab 4x4...pretty much stock, 2" 4 Crawler body lift and 32 x 11.50 bfg mud terrains.
Re: can any give some advise for an 22re? [Re: metal2dirt] #829861 08/10/07 05:54 AM
8
86yotatproject Offline
Hurry up and get that ***** fixed so we can wheel! i got thos TSL's off Brian.
86 P/U 84 Motor and TSL's. SAS and much more coming!
Re: can any give some advise for an 22re? [Re: 86yotatproject] #829862 08/10/07 06:19 AM
lethe Offline
my truck was like that when the timing was retarded
87' ext cab toy
Re: can any give some advise for an 22re? [Re: metal2dirt] #829863 08/10/07 06:22 AM
kewlynx Offline
It's a bit of a 2-part deal.
The ENGINE needs to be rotated to TDC on the compression stroke BEFORE you stab the distributor.
Rotor should be pointing at #1 once set.
Also remember that you have to jumper the diagnostic plug before you set your timing in order to take the TPS out of the loop.
**ubi apis- ibi salus**
Re: can any give some advise for an 22re? [Re: kewlynx] #829864 08/10/07 03:04 PM
Staceman Offline
Carbed 22R's time ay 0 degrees, with Vac Advance hoes disconnected.
EFI 22RE's, set the timing to 5 degrees, with the jumper installed.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6349 MB (Peak: 0.7409 MB) Data Comp: Off Server Time: 2026-06-21 00:11:59 UTC
