Re: can any give some advise for an 22re? [Re: Staceman] #829865 08/12/07 11:00 PM
8
86yotatproject Offline
OK so i get this right, to time the 22re you have to take the (TPS) out of the loop. so you do that how? and where exactly does that jumper wire go... And if you take the tps out it will alow you to make the adjustment? <img src="/forums/images/graemlins/confused.gif" alt="" />
ps got it timed but idels high, is that whytake the tps out of loop, to jump it efi main fuse to what?
Re: can any give some advise for an 22re? [Re: 86yotatproject] #829866 08/12/07 11:39 PM
8
84YOTA Offline
I believe you have to reset the efi computer to do so it should say in the manual of how to do it i know i read it in craigs manual under trouble codes...
You have to make the jumper wire and use it in the fuse box off the efi main fuses and jump the circuit to reset the efi system...and i believe this takes the tps out of loop..
-Brian
84 toyota std cab with stuff on it
Re: can any give some advise for an 22re? [Re: 86yotatproject] #829867 08/13/07 03:13 AM
drainsbe Offline
here is a pic of the check connector...
its in the same location as my 86... if the TPS is adjusted
correctly, then you should audibly hear the RPMs drop when you insert the jumper...
this is also the same connector to pull any codes stored in the ECU.
Good luck,
Dave
86 4Runner, 22R-EB
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6010 MB (Peak: 0.6704 MB) Data Comp: Off Server Time: 2026-06-21 12:22:48 UTC
