intake buildup #829940 08/10/07 12:50 AM
DanSweet Offline OP
What might be the cause of the white/yellow chalky buildup I'm finding in the bolt holes to hold my intake manifold to the head? There is so much build-up it completely caked the bolts in it as I pulled them out... coolant leak maybe? Thanks,
Dan
94' 22re Ex Cab 4x4...pretty much stock, 2" 4 Crawler body lift and 32 x 11.50 bfg mud terrains.
Re: intake buildup [Re: DanSweet] #829941 08/10/07 01:09 AM
kewlynx Offline
That and you live on the coast, so it'll tend to oxidize.
I put a small dab of antiseize compound on my bolts for reassembly; not much.
**ubi apis- ibi salus**
Re: intake buildup [Re: DanSweet] #829942 08/11/07 02:49 AM
canuck Offline
Usually a creamy globby mix substance is a water/antifreeze mixed with oil. Could it be a head gasket problem or a cracked head/block.
Keep the Shiney Side up. Support our troops.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5930 MB (Peak: 0.6458 MB) Data Comp: Off Server Time: 2026-06-07 04:22:37 UTC
