sputtering problem. #829943 08/10/07 12:52 AM
L
Littlewhitepup Offline OP
Ok so I have recently replaced my carb and by doing so it made my truck actually run ok. So now it will run good but at times i get this sputtering. Its kinda like it is miss firing. I have the timing set correct and everything good. Wondering if maybe its my dizzy going bad? or any other thing anyone knows about. I have a 2.3 pup.
Re: sputtering problem. [Re: Littlewhitepup] #829944 08/10/07 10:59 PM
L
any ideas? anybody?
Re: sputtering problem. [Re: Littlewhitepup] #829945 08/11/07 06:59 AM
A
all we'll drive Offline
Did you start with simple items like new spark plugs and wires? Good gas? How are you checking your timing? What was wrong with your old carb? Does it sputter only when cold/ hot, at idle? Is it running lean?
<img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
1995 Trooper 3.2 single, 5 speed, OME 912's, T-bar crank, G80, 285 M/T's, custom dents, random rust
1999 Trooper 3.5, auto, TOD, K&N, tint (wife's car can't improve it)
1988 Trooper LS 5 speed SOLD
Re: sputtering problem. [Re: all we'll drive] #829946 08/13/07 02:20 PM
L
new plugs, new wires, carb was all messed up and sticking. needed to be done. sputters randomly. checking timing with a timing light and a tach. dont know if it is running lean. the new carb has a fuel mixture screw and the stock one did not.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6008 MB (Peak: 0.6560 MB) Data Comp: Off Server Time: 2026-06-17 11:33:29 UTC
