Isuzu Wizard 4XJ1 engine, cranks but won't start #830110 08/10/07 07:25 AM
serowe Offline OP
I have a 1999 Isuzu Wizard 3l DOHC(Japanese import)4XJ1 engine, once I ran out of diesel, got the machenic to collect and service, drove 600 km the following day with no problem. Parked the vehicle for the night but on trying to start it the following morning, engine just cranked but would not fire. I have taken it to four different garages including Isuzu dealer in Sandton JHB, RSA.with no joy I am at my wits end and don't know what to do. Some say there is a problem with the fuel pump, not enough pressure, others say it is a ECU problem (Supplying 12V instead of 5V to Injectors and Cam and Crank Sensors. It will only fire if you use quickstart. Someone PLEASE HELP ME!!
Thank you.
Re: Isuzu Wizard 4XJ1 engine, cranks but won't start [Re: serowe] #830111 08/15/07 05:39 AM
Egelwolf Offline
Hi there
I noticed that you're also from Sunny SA... <img src="/forums/images/graemlins/smile.gif" alt="" />
Come and visit us at Isuzu Offroad. There's a bunch of guys that I'm sure will be able to help you.
'99 Isuzu Frontier (Rodeo) Intercooled 280DT LX
Re: Isuzu Wizard 4XJ1 engine, cranks but won't start [Re: serowe] #830112 08/16/07 02:34 PM
4
4jx1whisperer Offline
hey mate i work on these things all the time,they are a bit tricky just had a car that was parked and would not start.if it has manual trans try depressing the clutch .sometimes too much crankshaft end float wont let the crank position sensor pick up a signal if not try a can of aerostart a quick spray in the air intake may start it if it starts it is either a fuel or compression issue.they heavily rely on good compression for start up
Re: Isuzu Wizard 4XJ1 engine, cranks but won't start [Re: 4jx1whisperer] #830113 08/17/07 11:25 PM
comp Offline
let us know
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6038 MB (Peak: 0.6591 MB) Data Comp: Off Server Time: 2026-11-18 22:08:53 UTC
