rear axle seals
#830172
08/10/07 07:52 PM
i seem to be having a little touble getting my axles out it seems as if my ring gear is in the way of the pinion shaft can anyone tell me what i'm doing wrong its on a 1996 Isuzu Rodeo 6 cylinder 4x4
Re: rear axle seals
[Re: nickserbu]
#830173
08/10/07 08:03 PM
Ring gear and pinion shaft have nothing to do with pulling the axles. Once you have the flange bolts out, a good yank usually gets them to slide out. What vehicle are we talking about?
Re: rear axle seals
[Re: lttlbddy]
#830174
08/10/07 08:52 PM
tells us what you're doing and we'll be glad to tell you how its wrong! <img src="/forums/images/graemlins/lol.gif" alt="" />
-Rob
Re: rear axle seals
[Re: RobG]
#830175
08/10/07 11:10 PM
its a 1996 isuzu rodeo 4X4 with a 6 cylinder
Re: rear axle seals
[Re: nickserbu]
#830176
08/10/07 11:32 PM
Isuzu Moderator
WHAT are you trying to do? The ring gear cannot be in the way of the pinion shaft, or you have some other serious problems. The ring gear is in the way of the cross pin for the side spider gears, but even that does not need to be removed to pull the axles, as there are no c-clips.
As Rob asked, what exactly is it that you are trying to accomplish?
Michael
Re: rear axle seals
[Re: nickserbu]
#830177
08/13/07 07:39 PM
I was having a hard time getting my axle out as well after my outer bearing toasted itself and the seal. I ended up getting it out after several tries by using a hi-lift jack. I put the base of the jack against the frame and jacked the axle out of the tube. It was tough.
I had a spare axle in the garage that I was able to pull by hand. Two very different experiences pulling axles. A few years back when I pulled both axles to install a locker I pulled them both out by hand. It must have been the heat buildup from the bad bearing that cooked this last one into place.
Re: rear axle seals
[Re: HCMP]
#830178
08/13/07 07:42 PM
I should have added that you don't need to even take off the differential inspection cover to pull the axles. On an isuzu Dana 44 the axle is not c-clip retained. You should be able to take it out, easy or not, after you remove the brake caliper, rotor, and 4 backing plate bolts. its the backing plate bolts that hold it in. Not anything in the differential.
