Re: new lift - vibes [Re: DBL_DTY97TJ] #830379 08/14/07 04:18 PM
ksp2002TJ Offline OP
do you recall where you got your SYE/CV from? got a website or anything? everywhere I am finding is over $500.
Re: new lift - vibes [Re: ksp2002TJ] #830380 08/14/07 07:25 PM
DBL_DTY97TJ Offline
Sunray Engineering. www.sunrayengineering.com 817.594.9201
Prices may have gone up that much though...and that was parts only.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: new lift - vibes [Re: DBL_DTY97TJ] #830381 08/15/07 12:37 AM
guys, is this what is needed (everything pictured)?: http://cgi.ebay.com/ebaymotors/JKS-...itemZ190136498374QQrdZ1QQsspagenameZWD1V
Re: new lift - vibes [Re: ksp2002TJ] #830382 08/15/07 02:14 PM
DBL_DTY97TJ Offline
Looks like it. Basically just new output shaft, tail end of t-case, clips, and CV shaft. BUT you need to find out how much lift the shaft has been engineered for. Generally when someone is building a SYE/CV setup you need to measure the exact distance for the new shaft so it can be made to the right length. I'm sure it could be calculated based on JEEP model and lift though....just make sure that one will work with your 3" lift.
Re: new lift - vibes [Re: ksp2002TJ] #830383 08/15/07 02:17 PM
DBL_DTY97TJ Offline
WHat did they say at Sunray?
Re: new lift - vibes [Re: DBL_DTY97TJ] #830384 08/15/07 07:50 PM
I quickly looked through that site, but couldn't find it....I will have to call them directly. Let you know what I find out. Thanks!!
Re: new lift - vibes [Re: ksp2002TJ] #830385 08/15/07 09:18 PM
DBL_DTY97TJ Offline
They were really good to work with. Built my rear axle, complete with the 4:10's and ARB installed. Delivered when they said they would, incld. driveshaft, SYE, and new gears and ARB for my front end. I saved quite a while for that one. $$$ <img src="/forums/images/graemlins/lol.gif" alt="" />
But getting home again....Priceless.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6198 MB (Peak: 0.7136 MB) Data Comp: Off Server Time: 2026-10-24 02:36:57 UTC
