Re: fuel pressure [Re: BigJim] #830411 09/12/07 05:58 AM
doublediamonds Offline OP
well the only thing thats not new thats electrical is the plug wires most of that was already replaced or in the jeep when i bought it so i installed when the problems started, i tried replacing the coil wire when it died with a copper wire to just see if it would start back up but no luck
If you cant get there in a jeep you probably dont need to get there
Re: fuel pressure [Re: doublediamonds] #830412 09/12/07 03:16 PM
BigJim Offline
DD a copper wire won't work when it is running good...much less whan not running at all..
Re: fuel pressure [Re: BigJim] #830413 09/17/07 08:54 AM
a piece of solid core copper wire works just as well as the wire itself, ive used them as plug wires before when i had wires go out on me,
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.5966 MB (Peak: 0.6660 MB) Data Comp: Off Server Time: 2026-07-15 05:42:26 UTC
