Broken rear leaf spring #830522 08/13/07 01:15 AM
F
FarmerTed Offline OP
I noticed today that the third leaf down on the passanger rear of my 94 4x4 is broken. Is this uncommen? Where can I get a replacement? And do I have to replace the whole spring pack or can I just change out the broken leaf. No clue how long it's been this way.
1994 4x4 22RE
Re: Broken rear leaf spring [Re: FarmerTed] #830523 08/13/07 01:17 AM
G
Greg_Canada Offline
My cousins 88' did that too.
You can use a junkyard leaf, or jcwhitney sells stock replacements.
89 4Runner
Re: Broken rear leaf spring [Re: Greg_Canada] #830524 08/13/07 02:21 AM
stock87 Offline
Anyone here tried them? I'm considering them for a cheap & easy sag fix.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: Broken rear leaf spring [Re: stock87] #830525 08/13/07 02:57 AM
4Crawler Offline
I've seen a few folks on YotaTech use them. Supposed to work fairly well.
Re: Broken rear leaf spring [Re: stock87] #830526 08/13/07 07:46 AM
missouriman Offline
junk yard, you pull it should be cheap.
Re: Broken rear leaf spring [Re: FarmerTed] #830527 08/13/07 07:48 AM
Snowtoy Offline
Check with a local spring shop if you have one, or are close to an area that does. One spring shouldn't be to much if you do the work. Or as mentioned grab a set from a wrecking yard, shouldn't be more than about $30/set.
Re: Broken rear leaf spring [Re: Snowtoy] #830528 08/13/07 11:00 PM
Rauch_Off_Road Offline
Why not look into a chevy spring swap?
(aka suprathepeg, aka Sean)
Re: Broken rear leaf spring [Re: Rauch_Off_Road] #830529 08/13/07 11:31 PM
Scerb Offline
I ran jcwhittney springs for about 1.5yrs. Flexed about how a stock spring would, rode nice. I had no complaints
Re: Broken rear leaf spring [Re: Scerb] #830530 08/18/07 04:33 AM
F
Dealer wants $120 for just the single leaf or $550 for the spring pack. JC Whitney want $130 for each spring pack. Im may give JCW a try, but I'm going to check the Pic N Pulls first. What year springs will match the 94's?
1994 4x4 22RE
Re: Broken rear leaf spring [Re: FarmerTed] #830531 08/18/07 05:14 AM
OOP'S Offline
I broke the third leaf in an A-P pack once. Took a stock pack apart and took one of the leafs that was longer then the broken one. Lined up the center bolt hole on both and marked the longer leaf to the length of the broken leaf. Cut the excess off and put the A-P pack together. I thought it might lean a bit when I put it back on. It worked great, no lean, flexed great.
I think the rear springs on the 90-95 are the same.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6413 MB (Peak: 0.7603 MB) Data Comp: Off Server Time: 2026-06-23 11:15:18 UTC
