Reseting the (TPS) / ECU on 1986 22RE ???? #830566 08/13/07 04:52 AM
8
86yotatproject Offline OP
I put a new 22re long block in my 1986 toyota 4-runner.
started it and began timing it... and with it running good like still pulling it would idle at 1500 if i reved it . But if i turn it to where it idles normal but is way slugish... als i need is to be showen how o reset the ecu or adjust the TPS... some pics on it would help to thx ..,,..
... Its a 1986 4-runner 4x4 22re
86 P/U 84 Motor and TSL's. SAS and much more coming!
Re: Reseting the (TPS) / ECU on 1986 22RE ???? [Re: 86yotatproject] #830567 08/13/07 05:28 AM
8
Ok i got what to do now i need a pic r explained witch one's are the "T" & "E1" pins to short. i have the two yellowsh plugs that are driver side inner fender that pug in the black rubber holders in the fender.. just need 2know witch are the 2 jump or the color of the wires
Re: Reseting the (TPS) / ECU on 1986 22RE ???? [Re: 86yotatproject] #830568 08/13/07 05:43 AM
4Crawler Offline
Re: Reseting the (TPS) / ECU on 1986 22RE ???? [Re: 4Crawler] #830569 08/14/07 08:19 AM
8
right on, thank you
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6035 MB (Peak: 0.6597 MB) Data Comp: Off Server Time: 2026-06-17 13:25:48 UTC
