Carb Question. #830593 08/13/07 07:20 AM
8
86yotatproject Offline OP
I went wheelin a few times and got screwed on some hills. Just Boggin out at the top. I want to know if a weber, Holly, ect will do good on the hill climbs? anyone know of a good carb? Dont really want to do the EFI swap if i have to. 84 22r.
86 P/U 84 Motor and TSL's. SAS and much more coming!
Re: Carb Question. [Re: 86yotatproject] #830594 08/13/07 07:26 AM
kewlynx Offline
Wouldn't matter what carb you toss on there; gravity happens. You'll want to consider an electric fuel pump to install. I think Scerb is wearing one on his rig.
**ubi apis- ibi salus**
Re: Carb Question. [Re: kewlynx] #830595 08/13/07 01:27 PM
Scerb Offline
The stock carb really is the best offroad, however I have a Weber, just because I could basically. A float bowl overflow extension and fuel pressure regulator are probably the best things you can do. Theres some info on this in my carb faq (links in my signature). An electric fuel pump will do the same thing as the regulator (and no, kewlynx I don't have an electric pump).
The carb is still gonna stall when you go perfectly sideways, cause well, I flopped last night and it stalled <img src="/forums/images/graemlins/shiner.gif" alt="" /> (more info on this in a new thread once I get pics <img src="/forums/images/graemlins/kewl.gif" alt="" />).
-Scerb
Re: Carb Question. [Re: Scerb] #830596 08/24/07 07:58 PM
8
35 P.S.I What is a decent one?
Re: Carb Question. [Re: 86yotatproject] #830597 08/24/07 08:04 PM
4Crawler Offline
Some good carb. tweaks for steep angles on the page below:
http://www.pirate4x4.com/forum/showthread.php?t=541186&highlight=carb+float+bowl+overflow
I think you only need a few PSI for a carb fuel pump.
Re: Carb Question. [Re: 86yotatproject] #830598 08/30/07 08:33 PM
fourwd1 Offline
One of the best things to do is set the float level lower than spec.
I did that when I rebuilt mine any don't have any problems at steep angles.
Flopped over on the side, that's a different story.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6129 MB (Peak: 0.6827 MB) Data Comp: Off Server Time: 2026-06-07 00:51:59 UTC
