Bigger tires on 03 montero sport #830605 08/13/07 01:25 PM
Tonewhy Offline OP
I have been looking to get some new tires for my 2003 sport and was hoping to get a little taller look and maybe ones with a more aggressive tread. I would like to stay on the stock 16" rims. Just wanted to know if you guys have any recommendations on tires sizes or brands.
Thanks in advance<img src="/forums/images/graemlins/cheers.gif" alt="" />
Tony
Re: Bigger tires on 03 montero sport [Re: Tonewhy] #830606 08/13/07 02:10 PM
shadowgear Offline
Hello and Welcome to the wire! I did some digging around on this a while ago and found that LT265 75R16's fit fine without any issue. I think if you wanna go larger you will need a body/susp. lift. As far as tire brands, really depends on what type of driving you do (pavement/offroad/both) and weather you are expecting to drive in. I used BFG all terrains and have nothing but good things to say about them: good all around tire IMHO. Anyway, you also might want to check out Montero Sport Online for additional help/support specifically for the sport.
Cheers! <img src="/forums/images/graemlins/kewl.gif" alt="" />
'88 Raider 2.6L - SW Hubs, Weber 32/36, Off-road Pkg - Dead
'88 Monty 2.7L - 5" Lift, Weber 38, 33's, Dual Fans, Dual bouncy (more goodies to install) - Still Kicking.
'03 Monty Sport - XLS, BFG A/T's - Dead
Re: Bigger tires on 03 montero sport [Re: shadowgear] #830607 08/27/07 09:13 AM
Tonewhy Offline OP
Thanks Shadow for all your help on the tires. I got some 265 75R16 BFG All terrains and they fit perfectly. I also installed a Westin Roof rack and two Hella 3000 lights. I got two more in the deal, so hopefully I can get a front push bar to install the other two on. Anyways, I posted a pic of the lights after tonights late night install. Thanks again for your help.
Re: Bigger tires on 03 montero sport [Re: Tonewhy] #830608 08/27/07 02:40 PM
shadowgear Offline
No problem. Glad I could help out. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6011 MB (Peak: 0.6574 MB) Data Comp: Off Server Time: 2026-06-07 09:42:18 UTC
