New here #830675 08/13/07 11:59 PM
SuperTodd Offline OP
I am going to look at and hopefully buy a 1970 CJ5, 225 v6, bad t-14 trans, good body and hard top. What trannys can I put in place of the T-14 without much extra work or money
Re: New here [Re: SuperTodd] #830676 08/14/07 04:12 PM
DBL_DTY97TJ Offline
Welcome Supe,
Don't know diddly about CJ-5's, or about the T14, but it's usually easiest to replace with the same thing unless there is good reason not to. <img src="/forums/images/graemlins/cheers.gif" alt="" />
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: New here [Re: SuperTodd] #830677 08/15/07 01:57 PM
sweet97wrangler Offline
Hey there super T
I'm no expert either but you should be able to use a AX-15 out of 97 and newer tJ's possibly with a adapter plate, or the newer NV3500 or the NV4500 out of newer wranglers.
97 Wrangler Sport, 31" BFG All Terrain, .30 over 4.0L w/ Comp cam, P&P Head, Banks Header, Throttle body, chip.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5923 MB (Peak: 0.6449 MB) Data Comp: Off Server Time: 2026-06-21 12:22:21 UTC
