Re: Much needed help
[Re: highvan]
#830691
08/15/07 10:35 PM
its easy to pull the thermostat and check it out but if your losing fluid and there is no leak then not to sure what that would be.
"IM THERE BUDDY"
[Re: wytee]
#830692
08/16/07 02:38 AM
I got the old one and it was stuck shut, so i got a new one, put it in and let it run a bit, seems to be fixed <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: highvan]
#830693
08/24/07 07:50 AM
J Roll Me Over
For the speedo, take the cable back off of the t-case and attach it to a drill. Run the drill in reverse and see if the speedo moves.
If it moves, you need to replace the speedo adapter gears (about $30 at the dealer). 1 bolt holds the adapter, and then it all slides right out.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.5985 MB (Peak: 0.6678 MB) Data Comp: Off Server Time: 2026-06-21 16:14:05 UTCValid HTML 5 and Valid CSS
